2018-04-09, 06:57
Sorry if this is a silly question...
In the past I purchased Media Center Master to automatically edit my file info and artwork after using MkvToMp4 to convert and add subtitles. This was all done for iTunes as I use Apple Tv's.
I was hoping tMM would be able to do the same but I'm not sure if I have the setting turned on. It downloads the info and art but stores the files separately in the folder and doesn't edit the actual video files, so iTunes doesn't see any updates, is there a way to do this?
The only option I can think of is to open each episode on tMM and copy and paste it into the file info in iTunes which would take a long time.
Help appreciated, thank you
