(2019-06-07, 10:05)Aphykit2006 Wrote: HiI tested version xxx.13.beta4 but must revert to version xxx.12My layout : Titan titles (1 row of large title)Good :- Searching from music library is ok : great !
- New custom colors : OK (thanks)
- New View Circle
- Many other thinks
Cons- View panel square / Panel square details : Plots are not readables if background is not dark
- Font is to thin + missing overlay (May be i not found it in custom colors settings)
- With Plots, less pictures in the screen
- View Circle not really usable in some views : ie
- Too big for artists (only 10 / screen)
- Music Album : picture in the circle is not the album picture
- Skin settings : rounded , why not, but plots are difficutly readeables (see over)
- Netflix view (518) : clear logo over episodes pictures : how disable it ?
Suggest : News « circle View » like « View panel square » and « Panel square details »Suggest : Plots with 3 choices : over / under / offSelect plot fontDon’t work :- Artist Slideshow no more working when playing music
- Artwort settings / Extra Fanart
- with Skinhelper : don’t rotate (classic movie infoscreen)
- without skinhelper : stay black (classic movie infoscreen)
- Animated poster and Animated background : not working
Many Thanks
First thanks, for take your time into test the stuf
1: Colors are fine on my end.
- check corresponding colors
- which font are you refer ? Tag at Bottom ?, Colors can also be custom made, to "fit/go fine" with custom background
https://streamable.com/xchmi
2.
- 10 items are ok atm, may smaller on update 1.14
- But i will check ,for the artwork for albums THANKS
3. I will check, and also need to edit some visibility conditions, thanks for bring that up (had forget about that behaviour)
4. Extra Fanart is Working fine on my end (just need correct the fadetiome intervals ),
- but animations and artwork itself showing fine
- how are your extra artwork stored?
https://streamable.com/7ktfv
If you refer to animated artwork "GIF", i think its related to skinhelper, which i need to investigate
(PREPARE youself if you dot wanna lost existing "animated fanart" -> BACKUP
\userdata\addon_data\script.module.metadatautils\animatedgifs
