thank you ,i have install the package according to your given command right now it is working,but one error also come when run the make command.
please see this code.
PeripheralCecAdapter.cpp: In member function ‘virtual void PERIPHERALS::CPeripheralCecAdapter::Announce(ANNOUNCEMENT::AnnouncementFlag, const char*, const char*, const CVariant&)’:
PeripheralCecAdapter.cpp:168:25: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOnScreensaver’
if (m_configuration.bPowerOnScreensaver == 1 && !bIgnoreDeactivate &&
PeripheralCecAdapter.cpp:177:108: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOffScreensaver’; did you mean ‘bPowerOffOnStandby’?
if ((!g_application.m_pPlayer->IsPlaying() && !g_application.m_pPlayer->IsPaused()) && m_configuration.bPowerOffScreensaver == 1)
bPowerOffOnStandby
PeripheralCecAdapter.cpp: In member function ‘virtual bool PERIPHERALS::CPeripheralCecAdapter::InitialiseFeature(PERIPHERALS:
eripheralFeature)’:
PeripheralCecAdapter.cpp:243:17: error: ‘CEC::ICECCallbacks {aka struct CEC::ICECCallbacks}’ has no member named ‘CBCecLogMessage’; did you mean ‘logMessage’?
m_callbacks.CBCecLogMessage = &CecLogMessage;
logMessage
PeripheralCecAdapter.cpp:244:17: error: ‘CEC::ICECCallbacks {aka struct CEC::ICECCallbacks}’ has no member named ‘CBCecKeyPress’; did you mean ‘keyPress’?
m_callbacks.CBCecKeyPress = &CecKeyPress;
keyPress
PeripheralCecAdapter.cpp:245:17: error: ‘CEC::ICECCallbacks {aka struct CEC::ICECCallbacks}’ has no member named ‘CBCecCommand’
m_callbacks.CBCecCommand = &CecCommand;
PeripheralCecAdapter.cpp:246:17: error: ‘CEC::ICECCallbacks {aka struct CEC::ICECCallbacks}’ has no member named ‘CBCecConfigurationChanged’; did you mean ‘configurationChanged’?
m_callbacks.CBCecConfigurationChanged = &CecConfiguration;
PeripheralCecAdapter.cpp:247:17: error: ‘CEC::ICECCallbacks {aka struct CEC::ICECCallbacks}’ has no member named ‘CBCecAlert’
m_callbacks.CBCecAlert = &CecAlert;
PeripheralCecAdapter.cpp:248:17: error: ‘CEC::ICECCallbacks {aka struct CEC::ICECCallbacks}’ has no member named ‘CBCecSourceActivated’; did you mean ‘sourceActivated’?
m_callbacks.CBCecSourceActivated = &CecSourceActivated;
sourceActivated
rocess()’:
PeripheralCecAdapter.cpp:416:32: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bSendInactiveSource’; did you mean ‘bActivateSource’?
else if (m_configuration.bSendInactiveSource == 1)
bActivateSource
PeripheralCecAdapter.cpp: In static member function ‘static int PERIPHERALS::CPeripheralCecAdapter::CecCommand(void*, CEC::cec_command)’:
PeripheralCecAdapter.cpp:627:89: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bShutdownOnStandby’; did you mean ‘bPowerOffOnStandby’?
(adapter->m_configuration.bPowerOffOnStandby == 1 || adapter->m_configuration.bShutdownOnStandby == 1) &&
bPowerOffOnStandby
PeripheralCecAdapter.cpp:633:43: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bShutdownOnStandby’; did you mean ‘bPowerOffOnStandby’?
else if (adapter->m_configuration.bShutdownOnStandby == 1)
bPowerOffOnStandby
PeripheralCecAdapter.cpp:638:36: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bUseTVMenuLanguage’; did you mean ‘strDeviceLanguage’?
if (adapter->m_configuration.bUseTVMenuLanguage == 1 && command.initiator == CECDEVICE_TV && command.parameters.size == 3)
strDeviceLanguage
PeripheralCecAdapter.cpp: In member function ‘void PERIPHERALS::CPeripheralCecAdapter::SetConfigurationFromLibCEC(const libcec_configuration&)’:
PeripheralCecAdapter.cpp:1264:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bUseTVMenuLanguage’; did you mean ‘strDeviceLanguage’?
m_configuration.bUseTVMenuLanguage = config.bUseTVMenuLanguage;
strDeviceLanguage
PeripheralCecAdapter.cpp:1264:47: error: ‘const libcec_configuration {aka const struct CEC::libcec_configuration}’ has no member named ‘bUseTVMenuLanguage’; did you mean ‘strDeviceLanguage’?
strDeviceLanguage
PeripheralCecAdapter.cpp:1265:66: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bUseTVMenuLanguage’; did you mean ‘strDeviceLanguage’?
bChanged |= SetSetting("use_tv_menu_language", m_configuration.bUseTVMenuLanguage == 1);
strDeviceLanguage
PeripheralCecAdapter.cpp:1270:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOffScreensaver’; did you mean ‘bPowerOffOnStandby’?
m_configuration.bPowerOffScreensaver = config.bPowerOffScreensaver;
bPowerOffOnStandby
PeripheralCecAdapter.cpp:1270:49: error: ‘const libcec_configuration {aka const struct CEC::libcec_configuration}’ has no member named ‘bPowerOffScreensaver’; did you mean ‘bPowerOffOnStandby’?
bPowerOffOnStandby
PeripheralCecAdapter.cpp:1271:69: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOffScreensaver’; did you mean ‘bPowerOffOnStandby’?
bChanged |= SetSetting("cec_standby_screensaver", m_configuration.bPowerOffScreensaver == 1);
bPowerOffOnStandby
PeripheralCecAdapter.cpp:1273:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOnScreensaver’
m_configuration.bPowerOnScreensaver = config.bPowerOnScreensaver;
PeripheralCecAdapter.cpp:1273:48: error: ‘const libcec_configuration {aka const struct CEC::libcec_configuration}’ has no member named ‘bPowerOnScreensaver’
PeripheralCecAdapter.cpp:1274:66: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOnScreensaver’
bChanged |= SetSetting("cec_wake_screensaver", m_configuration.bPowerOnScreensaver == 1);
PeripheralCecAdapter.cpp:1278:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bSendInactiveSource’; did you mean ‘bActivateSource’?
m_configuration.bSendInactiveSource = config.bSendInactiveSource;
bActivateSource
PeripheralCecAdapter.cpp:1278:48: error: ‘const libcec_configuration {aka const struct CEC::libcec_configuration}’ has no member named ‘bSendInactiveSource’; did you mean ‘bActivateSource’?
bActivateSource
PeripheralCecAdapter.cpp:1279:66: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bSendInactiveSource’; did you mean ‘bActivateSource’?
bChanged |= SetSetting("send_inactive_source", m_configuration.bSendInactiveSource == 1);
bActivateSource
PeripheralCecAdapter.cpp:1282:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bShutdownOnStandby’; did you mean ‘bPowerOffOnStandby’?
m_configuration.bShutdownOnStandby = config.bShutdownOnStandby;
bPowerOffOnStandby
PeripheralCecAdapter.cpp:1282:47: error: ‘const libcec_configuration {aka const struct CEC::libcec_configuration}’ has no member named ‘bShutdownOnStandby’; did you mean ‘bPowerOffOnStandby’?
bPowerOffOnStandby
PeripheralCecAdapter.cpp:1291:30: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bShutdownOnStandby’; did you mean ‘bPowerOffOnStandby’?
m_configuration.bShutdownOnStandby == 1 ? 13005 : 36028);
bPowerOffOnStandby
PeripheralCecAdapter.cpp: In member function ‘void PERIPHERALS::CPeripheralCecAdapter::SetConfigurationFromSettings()’:
PeripheralCecAdapter.cpp:1367:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bUseTVMenuLanguage’; did you mean ‘strDeviceLanguage’?
m_configuration.bUseTVMenuLanguage = GetSettingBool("use_tv_menu_language") ? 1 : 0;
strDeviceLanguage
PeripheralCecAdapter.cpp:1369:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOffScreensaver’; did you mean ‘bPowerOffOnStandby’?
m_configuration.bPowerOffScreensaver = GetSettingBool("cec_standby_screensaver") ? 1 : 0;
bPowerOffOnStandby
PeripheralCecAdapter.cpp:1370:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bPowerOnScreensaver’
m_configuration.bPowerOnScreensaver = GetSettingBool("cec_wake_screensaver") ? 1 : 0;
PeripheralCecAdapter.cpp:1371:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bSendInactiveSource’; did you mean ‘bActivateSource’?
m_configuration.bSendInactiveSource = GetSettingBool("send_inactive_source") ? 1 : 0;
bActivateSource
PeripheralCecAdapter.cpp:1376:19: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bShutdownOnStandby’; did you mean ‘bPowerOffOnStandby’?
m_configuration.bShutdownOnStandby = iStandbyAction == 13005 ? 1 : 0;
bPowerOffOnStandby
PeripheralCecAdapter.cpp: In member function ‘void PERIPHERALS::CPeripheralCecAdapterUpdateThread::UpdateMenuLanguage()’:
PeripheralCecAdapter.cpp:1523:23: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bUseTVMenuLanguage’; did you mean ‘strDeviceLanguage’?
if (m_configuration.bUseTVMenuLanguage == 1)
strDeviceLanguage
PeripheralCecAdapter.cpp:1527:79: error: no matching function for call to ‘CEC::ICECAdapter::GetDeviceMenuLanguage(CEC::cec_logical_address, char (*)[4])’
if (m_adapter->m_cecAdapter->GetDeviceMenuLanguage(CECDEVICE_TV, &language))
In file included from PeripheralCecAdapter.cpp:38:0:
/usr/include/libcec/cec.h:186:25: note: candidate: virtual std::__cxx11:
tring CEC::ICECAdapter::GetDeviceMenuLanguage(CEC::cec_logical_address)
virtual std:
tring GetDeviceMenuLanguage(cec_logical_address iLogicalAddress) = 0;
/usr/include/libcec/cec.h:186:25: note: candidate expects 1 argument, 2 provided
PeripheralCecAdapter.cpp:1528:43: error: request for member ‘language’ in ‘language’, which is of non-class type ‘CEC::cec_menu_language {aka char [4]}’
m_adapter->SetMenuLanguage(language.language);
PeripheralCecAdapter.cpp: In member function ‘std::__cxx11:
tring PERIPHERALS::CPeripheralCecAdapterUpdateThread::UpdateAudioSystemStatus()’:
PeripheralCecAdapter.cpp:1547:69: error: array must be initialized with a brace-enclosed initializer
cec_osd_name ampName = m_adapter->m_cecAdapter->GetDeviceOSDName(CECDEVICE_AUDIOSYSTEM);
PeripheralCecAdapter.cpp:1548:126: error: request for member ‘name’ in ‘ampName’, which is of non-class type ‘CEC::cec_osd_name {aka char [14]}’
CLog::Log(LOGDEBUG, "%s - CEC capable amplifier found (%s). volume will be controlled on the amp", __FUNCTION__, ampName.name);
PeripheralCecAdapter.cpp:1549:53: error: request for member ‘name’ in ‘ampName’, which is of non-class type ‘CEC::cec_osd_name {aka char [14]}’
strAmpName += StringUtils::Format("%s", ampName.name);
PeripheralCecAdapter.cpp: In member function ‘bool PERIPHERALS::CPeripheralCecAdapterUpdateThread::SetInitialConfiguration()’:
PeripheralCecAdapter.cpp:1586:66: error: array must be initialized with a brace-enclosed initializer
cec_osd_name tvName = m_adapter->m_cecAdapter->GetDeviceOSDName(CECDEVICE_TV);
PeripheralCecAdapter.cpp:1587:96: error: request for member ‘name’ in ‘tvName’, which is of non-class type ‘CEC::cec_osd_name {aka char [14]}’
strNotification = StringUtils::Format("%s: %s", g_localizeStrings.Get(36016).c_str(), tvName.name);
rocessStandbyDevices()’:
PeripheralCecAdapter.cpp:1733:30: error: ‘CEC::libcec_configuration {aka struct CEC::libcec_configuration}’ has no member named ‘bSendInactiveSource’; did you mean ‘bActivateSource’?
bActivateSource
/home/mannan/xbmc/Makefile.include:97: recipe for target 'PeripheralCecAdapter.o' failed
make[1]: *** [PeripheralCecAdapter.o] Error 1
Makefile:420: recipe for target 'xbmc/peripherals/devices/peripheral-devices.a' failed
make: *** [xbmc/peripherals/devices/peripheral-devices.a] Error 2
make: *** Waiting for unfinished jobs....
C
