Hello guys I've been reading religiously numerous tutorials to make IAGL work on my tv box but didn't succeed.
I've got a minix u1 s905 based, the wiki points me to install an open elec distro instead of using android.
So there's no chance to make it work on android ?
thanks
It works, thanks !
I've got a question, when I try do load a psx game it doesn't prompt me for which core I want to use, it just sits there doing nothing. I click on launch but nothing happens
Yes I've downloaded the bios with retroarch and yest other platform works. Launcher set to internal
Amazing work Zach. I just attempted to IAGL along with Retro Arch. The game list looks incredible. I was watching a video by David Young using IARl. There no options in the Setup Wizard for an external emulator right now. It is default Kodi Retroplayer and way to change it. I would try that after if I fail at Retro Arch. Later in the video, you have to press C to get to the menu he showed how to click on the Update Exe Launcher Command. That option isn't there either now. I went to Zach Morris Github site and the FAQ's stated the same thing about it being possible. Thanks in advance for your assistance. Keith
2018-10-24, 11:37
(This post was last modified: 2018-10-24, 11:39 by Wintermute0110.)
Hi Zach,
Congrats by IAGL. I installed last week to do some tests and found some issues. I am using Linux installed on an Intel NUC with external Retroarch. Retroarch binary is installed on /home/kodi/bin/retroarch
, the libretro cores are in /home/kodi/bin/libretro/
, and the system directory is /home/kodi/.retroarch/system/
1) I am unable to launch external Retroarch. In the settings, I told IAGL where Retroarch is installed, that my system is "Linux/Kodibuntu" (by the way, Kodibuntu is obsolete right now), to use an external launcher and then executed the setup wizard to rebuild all databases. In a ROM list context menu, if I watch the launcher configuration is is correctly configured as external. However, the launch command uses -L /usr/lib/retroarch/xxxxx_libretro.so
. Is there a way to configure the Libretro core directory when calling Retroarch externally?
2) In IAGL settings why you have to configure the Retroarch System directory but there is no option to configure the Retroarch Cores directory?
3) When viewing the List of Systems/Platform lists (the "launchers") the order is random, and you cannot change it in the view context menu. The sorting methods are disabled, included the alphabetical one.
4) I love the "Best of..." launchers. Many of them present in IARL are missing from IAGL. Are you planning to revive all of those?
I do not have a debug log at the moment but let me know if you need one.
Thanks for the response Zach. The external launchers tab is the same as the video. I have Retro Arch there with the app location and system location. However, there are only two options in the list compared to the video I watched. On David Young's video, it recognized that he was using an external launcher. I kept pressing enter and using my mouse yesterday to make it change to external but wouldn't work. Right now it allowed me to change it. Sorry to bother you. Have a great day.
2018-10-25, 16:22
(This post was last modified: 2018-10-25, 16:32 by DaVu.)
Hey Zach. I wrote last night to save time while I was sleeping, but it's not here. My keyboard was not compatible with Retro Arch so I have to use Retroplayer instead. So I set up everything according to this:
Link removed by DaVu
I put in the link in file manager and followed the steps through choosing English. However, there no apps called Retroplayer or Game Providers. Are they the same? How do you find them in Kodi? I've been trying to google this all night. Thanks again for your assistance.
Keith
My apologies. I have a neurological disorder so I forget a lot of short term memory. Long term I'm fine.
Hey Zach. I was gave up on Retro Arch last night because I couldn't figure out how to use the keyboard. The solutions were foreign to me. I was referring to where is Retroplayer on Kodi. I added the URL and set it up following the instructions. However, there is no Retroplayer or Game Providers on my Kodi anywhere. Are they the same? How do I locate the addon? I set it up through English your repository. The games don't launch because there is no Retroplayer or Game Providers anywhere. Appreciate the help.
yougz
Junior Member
I have a problem and I have not managed to find the answer in the tutorials.
When I want to run a game of more than 100mo (like dreamcast) I have a message that says "archive returned no file or requires login in settings" but I have not found any adequate menu in the settings
Sorry for my English I am French and I use Google translation.
In advance, thank you for your answer
