Hi
I'm absolutely disappointed with this update. The Kodi app isn't reading my external hard drive 2TB NTFS format. whenever i select movies ->my hard drive. the error showing "Remote share - Path not found or invalid"
Earlier in marshmallow, it was working fine. Please forward this message to Kodi developers to fix this bug and bring a new update or guide me to solve this issue.
Same here
Xiaomi Mi Box with 5GB USB harddisk
You are right with your hint. The tone makes the music.
On topic. I was using a disklabel but after the update Kodi cannot access the USB disc anymore.
Same problem here...was working great before the oreo update on the mi box 3...the box can "see" the drive and access it with other programs, only kodi is "confused??" since it reads the disk label correctly but the "Remote share - Path not found or invalid" error appears.
Any suggestions other than get the drive on FAT32 :S
Hi....I would be greatly appreciated if the external hard drive Kodi problem could be resolved. I'm experiencing very much the same problem as above....When the MI Box was on Andriod TV 6.0, my Western Digital 3 TB external was working fine, but after the Andriod update that was pushed to the device, the drive can no longer be read and gives that "Path not found or Invalid" message as stipulated above.
Many Thanks,
Brenden
The drive is formatted with NTFS. Tried a thumb drive formatted with both exFat and NTFS. Both did not read. But when I reformatted it with Fat32, it was picking up just fine....Hope that is enough to go on....
Meanwhile VLC Player is working well on MI Box with the HD problem but no real substitution to KODI.
Agreed....VLC is mearly a media player, while KODI is a media server and far more rich in terms of functionality....cont compare...
Update: Finding the same issue after intalling Kodi alpha version.
Klojum
Lost connection
Anyone with an Nvidia Shield running Android Oreo and Kodi Leia already with these external HDD problems?
I think it's related to the same problem. Downloading subtitles in Kodi error message Can not download subtitle.
Before update was OK in my opinion its related to the same problem with problem accessing shared folders.
Can Kodi on Android TV save subtitle directly in video folder on shared drive?
replying just to keep this thread, so it gets the attention.. was a happy user with kodi till the oreo update on mi box.. don't want to try out any other alternatives..
