2019-11-13, 21:17
(2019-11-13, 19:50)ESCO1 Wrote: @Video Titles As far as the loading/buffering red ring on the splash screen you're right that must be due to updating library through the emby addon. I don't wish to disable the auto update because titles are always being added but am sure there is a way to hide it. I looked through as many xml to find it but couldnt' find it so i can disable the code. I looked at "startup" "home" etc xml and didnt' come across. Maybe you or someone else can help out. I tried to pm the skinner and its been weeks with no reply so yo no se lol.
I cannot do anything tonight, I just tried I even had to turn the light on, but as I have said previously due to building work that is currently going on in my location, and future building work that is happening in my living area, I have had to change my living space to bare minimum, my old set up had a monitor and also a TV set up, plus keyboard, mouse etc, so I could use that cinema PC during the day as a normal PC and as a cinema pc during the night time.
As it stands I only have a wireless keyboard and the computer is attached to the TV and not a monitor, so I am sat feet away from the TV on a wireless keyboard, I tried to reinstall ORB Studio to do a video capture, but I could not get that working, codecs missing or something.
I do have a print screen on the wireless keyboard but despite me pressing that, shift and that, alt and that, it would not copy to the clipboard so I could not even take a screen shot.
Here are a couple of video's from youtube about what your set up should look like.
https://www.youtube.com/watch?v=bS7bu98fyRM This one is buffering at 0:26 it is because it is trying to load pre installed playlists, which do not really work that well, you need to remove those completely and create your own playlists.
https://www.youtube.com/watch?v=cTnEo3ZBs1E this is sort of how Bingie should look once you set it up, so you can see why I say that you have not set yours up properly as yet.
You also have video settings that this person does not have set, such as enable circular navigation, which hides the left menu bar.
Hopefully you can see the difference, I just done a youtube quick search, I have not watched the whole of these videos, only the first few seconds and skipping ahead a bit, however the first video shows white buffering ring to load up a playlist included with Bingie which slows it down. The red ring which will be in the top right is when it is updating the movie library.
I had to jump on my office PC to type this, as trying to type from three feet away is kind of difficult at times, which is why it is kind of awkward to have tried helping you as much as I would have done. I was hoping someone whom does not have the problems that I do at the moment might have helped you.
Hopefully you can tell the difference between the two videos, the second one is in Spanish, so apologies for that. It was just the two easiest videos that I found.
