Thanks for the post. Is it mainly the red text or do you have trouble with the white as well. Pretty much anything red means I haven't gotten around to editing it yet. Red is nice in Back-Row but it doesn't match leo.
The play pause thing is easy to fix. The options are behind the semi-transparent background instead of in front of it. That whole thing will be eventually changed to look more like vlc or quicktime controls on a mac, so I hadn't bothered to fix it. If it makes it more useable I'll go ahead and fix that
I am having problems with the white text .. it is all black everywhere.. but dont know whether it is a problem related to the skin since it works in windows .. It is in linux the problem is related too :S
What operating system does this work for?
rwparris2
Team-XBMC Python Developer
'tis a shame this is so slow on my xbox. Looks beautiful...
Updated version on my site, listed earlier in the post. Smaller and quicker but not alot of new stuff
The experience on the xbox is much improved on this version. In the last one backgrounds kept not showing up but that seems to be fixed in this revision There are some really great views in this skin and it looks good all round.
The only issues I had with it is that in the home window the pop-up icons didn't all show up. The setting icon didn't pop up at all and the tv and photos icons were occasional. These problems don't seem to exist in the "window" version so I assume that its a memory usage problem.
The interchange between screens wasn't what I'd call snappy but then again it isn't in Back row ether. The last thing is personal preference I think it would be better to have the dark mask in the home screen of by default
I'm looking forward to seeing how this skin progresses keep up the good work
Hitcher
Team-Kodi Member
I've downloaded the zip file but there's no build.bat.
I'll be speeding up the transitions and trying to optimize memory usage. The dock is a real memory hog so I rewrote it and still have a few more things to change on it to make it's foot print smaller. I plan to add an option to turn it off but I am not sure how that will affect its memory footprint. I may add an option to turn of transitions if people want it.
texture files can now be made on os x so I will be trying that out for the next update.
