Just released:
v3.15.4
- Fixed: In 3.15.2 WebIf that is not OpenWebIf does not support auto timer API - Addon won't load Newnigma2 image, fixes #151
Above fix is for older dreamboxes
Sorry for the most likely stupid question, but on libreleec 8.2.2.3, kodi 17.6. addon keeps failing to install. am i pi$$ing against the wind here?
thanks
Paul
Can someone share the 3.14 version for android? I can't install the last version on Kodi leia RC4 and 13.4 seems the most stable. I recently lost my "external storage" and can't recover the 3.14 from old addons folder on kodi. Thanks
The release above is only source code. You would need to build it from there.
Can you post the issues you are having with the latest version as those issues will need to be fixed for all Android users?
v3.16.0 just released
Added: Tuners and SignalStatus
Added: Use Picon Path from OpenWebIf
Fixed: Change startup issue log statements from Debug to Error
