  • 25
  • 26
  • 27(current)
  • 28
  • 29
  • 48
Vu+ PVR addon is getting updates again
(2019-03-10, 10:55)ksooo Wrote:
(2019-03-10, 08:17)florian111 Wrote: @phunkyfish
danke für deine updates und arbeit
gruß
florian
This is an English speaking forum and @phunkyfish most probably did not understand a single word as he is Irish.
 Correct, not a clue.
Maintainer of Enigma2 PVR addon: repo, docschangelog
How to create a full debug: here
v3.20.0 released:
Added: Add options to Tune Async connection for slower E2 devices
Added: Enable option to reload channels and groups once per day if changes are detected
Added: Allow timers generated by autotimers to be deleted
Fixed: Fix for disabling timers
Added: Use genre from kodi for timers instead of lookup where possible
Added: Support recording type fully for TV/Radio/Any channel
Added: By default load Last Scanned group if no TV groups found
Added: Limit autotimers to TV/Radio or originating channel's groups
Fixed: Channel Service Refs Can sometimes have alphabetic characters appended at the end, fixes #202
Added: For timers and autotimers without a valid channel put in error state instead of omitting
Fixed: IsRunning timer check not checking start time
gruß
florian
He says: "Thanks for the (addon) updates and for the work you are doing."
(2019-03-10, 10:55)ksooo Wrote: This is an English speaking forum and @phunkyfish most probably did not understand a single word as he is Irish.
He’s very welcome 😉
v3.21.0 released
- Added: Support Edit Recording name, last played and play count
- Fixed: Use v3.6.1 of nlohmann/json to relax cmake version dependency for OSMC, fixes #194
- Added: Nightly channel reload check as default
- Added: Split out and move openwebif version checking to settings
(2019-03-22, 17:16)phunkyfish Wrote: v3.21.0 released
It shows an update to 3.20 at this moment (I wasn't quite up to date), and while installing that version, Kodi crashes. I wait till 3.21 is refreshed on the update server Wink
Kodi 19.1 Android/Google(TV) [ Shield TV Pro [64b] / Mi Box S [32b] / Mi Projector / Fire 4k TV stick / CC with Google TV ]
Kodi 19 [3D MVC build] Shuttle DH270 [Kaby Lake i3-7300/HD630 graphics - W10-1903]
Can you post a debug log for 3.20? If you have an issue some other users may find the same problem. Would be good to fix as soon as possible.
Can't do that, the update for 3.21 installed just fine without any problem.
(2019-03-22, 19:25)p750mmx Wrote: It shows an update to 3.20 at this moment (I wasn't quite up to date), and while installing that version, Kodi crashes. I wait till 3.21 is refreshed on the update server Wink
Then it’s nothing to worry about!
v3.22.0 released:
Added: Help info for addon settings
Added: Delete child timers when deleting autotimers
Added: Set max connection check interval to 60 seconds
Fixed: Incorrect localisation IDs
Fixed: Timers in error state cause crash on delete
Added: Support show info fields for Timers
Note that unless you are using testbuilds you won't see the help info in settings until Kodi 18.2 is out.
Any issues with recording programme data at moment?
My last 3 recordings all have the wrong information, despite the guide screen showing the correct info at the time of recording.
Not that I’ve noticed.
Affected recordings in Kodi are showing zero guide data on my STB. so very likely an issue with the hardware then...
(2019-04-09, 00:52)Dumyat Wrote: Affected recordings in Kodi are showing zero guide data on my STB. so very likely an issue with the hardware then...
Try restarting your STB and rerunning however you update your guide data. After that restart kodi and see what happens.
Cheers.
Have tried that and will see if that fixes the issue. I've been tinkering between using EIT and Rytec data as Openvix now support my device and I'm using their latest image, so maybe that's caused a conflict somewhere. I've noticed lately that most of my shows are returning genre as either 'Series' or 'Show/Game Show'. At first I thought the problem was at the Kodi end, but checking the source guide data on the STB this how the genre tag is being captured. Guess something must have changed in how the source data is collected as 90% of shows now all show the same genre....
  • 25
  • 26
  • 27(current)
  • 28
  • 29
  • 48
Vu+ PVR addon is getting updates again3
