  • 36
  • 37
  • 38(current)
  • 39
  • 40
  • 48
Vu+ PVR addon is getting updates again
same outcome Sad
https://paste.ubuntu.com/p/yvgZTJnTHJ/
https://paste.ubuntu.com/p/9BC8H3W9cY/
My mistake, I missed one. Will have you another build shortly.
Maintainer of Enigma2 PVR addon: repo, docschangelog
How to create a full debug: here
Here you go: https://jenkins.kodi.tv/job/kodi-pvr/job...3.28.8.zip
Do you have any issues seeing recordings/timers correctly on win32? I.e. comparing them against Win10 to see if they are exactly the same.
It is ALIVE! It work now! THX
Now when I try to STOP the recording I get an error that I can not stop it ... but KODI does not crash.
https://paste.ubuntu.com/p/5R5TD9NHYB/
Ya, that's one of the other many instances I need to clean up but we have a solution which is cool Wink
So from there there are a few things to do:
1) Make sure that you can see recordings and timers correctly in kodi win32 matching win10.
2) Clean up this fix and finish it.
3) Test the same fix on Win10 (I'll need to give you another zip for win10).
4) Test the same fixes on Kodi Matrix (i.e. Kodi 19 Alpha), win32 and win10. Once we get to that point could you help do that as I don't have a windows system?
If you can check 1), I'll work on getting 2/3 ready.
1) the timers and recordings are shown OK in every instance of my KODI installations - Win x64 / Win x86 / RPI3 Libreelec ( they match the ones on the VU+ Zero )
3) standing by for updates Smile
4) Just say the word, I can test Win x86 / Win x64 - 17.x, 18.x, 19.x
Thanx again for all Your effort!
Builds for Leia:
Ok, final fix to test on Win32/x86: https://jenkins.kodi.tv/job/kodi-pvr/job...3.28.8.zip
And final fix to test on Win10/64bit: https://jenkins.kodi.tv/job/kodi-pvr/job...3.28.8.zip
Will post Matrix fix later.
Just ti be clear, when You say Win32 you refear to x86 windows installations, and when You say Win10 you mean x64 windows installations?
Correct.
And here are the builds for Matrix:
win32/x86:
https://jenkins.kodi.tv/job/kodi-pvr/job...-4.9.3.zip
Win10/64bit:
Tested win32/x86 on 18.4 - recording starts, but stopping still not working
https://paste.ubuntu.com/p/yMHD9BKCh7/
Can you also post the output of http://192.168.1.20:82/web/timerlist
It is empty at the moment ... do you want me to set some timers from KODI and then post it?
So add a timer using x86 addon, then capture output of web/timerlist (should be one entry). Then delete the timer and post the debug log too. Then I can try and figure out why you get the error.
It appears to load the timer and loads start time correctly but end time is 0. And it needs both to be able to delete.
Also, are you recording from EPG or from the a live stream? I guess try one of each.
Would also be good to check if you can update a timer.
Win10x86-Kodi19
I can add timer from EPG Guide, the sheduled task apperas on VU+, and I can delete the timer from timerlist.
https://paste.ubuntu.com/p/YGD6sspJ5K/
https://paste.ubuntu.com/p/T4bRzftR7b/
I hope I understood what You need, if not please elaborate more Smile
I will repeate this task for every operating system that you needed.
  • 36
  • 37
  • 38(current)
  • 39
  • 40
  • 48
Vu+ PVR addon is getting updates again3
