2018-12-09, 11:07
(2018-12-09, 10:44)DaMacFunkin Wrote:I don't believe they are - where are you seeing reports that DV UHD Blu-rays are playing on Apple TV 4K? AIUI The Apple TV is playing single stream DV back - but not dual stream. (There is no commercial reason for the ATV 4K to play back dual stream content as all streaming services will be single stream)(2018-12-08, 12:53)noggin Wrote:So how are Apple TV users re-muxing their streams to be able to playback in DV?(2018-12-08, 10:59)DaMacFunkin Wrote: Sorry my bad then, I just presumed that because dvdfab etc would mix out the second video stream in a DV blu ray that that was how it was working on the Apple TV.
So is there a a way to create a single stream DV file from UHD blu ray?
Not available to mere mortals. (There may be some high-end proprietary Dolby mastering software that allows for this - but there's nothing available to general Kodi users)
HOWEVER - https://mrmc.tv/forum/viewtopic.php?f=15...1&start=40 seems to suggest that https://github.com/DolbyLaboratories/dlb...master/bin may allow you to do something clever...
https://www.reddit.com/r/Piracy/comments...x/e75t9oa/ was the source (the --progress seems to be a red herring and should be omitted)
There is some discussion in the reddit though as this looks to be a remux not a profile change - so it may not be doing what people think it is. (i.e. not changing a dual stream to a single stream and instead just muxing the base and enhancement dual stream layers into an MP4)
https://www.dolby.com/us/en/technologies...levels.pdf has more information.
There are LG demo transport streams in different DV flavours in the wild.
The first one has dvhe.05.09 - which means Profile 05 (single base layer 10-bit HEVC)
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@Main
Dolby Vision : 1.0, dvhe.05.09, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 34.3 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Codec configuration box : hvcC+dvcC
This stream which is dvhe.04.06 - which means Profile 04 (10-bit HEVC base layer with 1/4 resolution 10-bit HEVC 4.1 enhancement layer) which I believe is a dual-stream?
Video
Menu ID : 2 (0x2)
Format : HEVC
Format profile : Main 10@L5@Main
Dolby Vision : 1.0, dvhe.04.06, BL+EL+RPU
Codec ID : 36
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Bit depth : 10 bits
