  • 44
  • 45
  • 46(current)
  • 47
  • 48
  • 119
2018 - Amazon Fire TV Stick 4K
Does the firestick 4k support hard drives formatted in ntfs through the usb and otg suggested in this thread? I have read somewhere that in only supports fat32
I buy the Stick 4K Yesterday and i have a problem .
I' m not able to see Jack Ryan from Prime Video ( the video don' start and a message said me to contact assistence).
No problem to see Jack Ryan from Nvidia Shield trhought app.
(2019-11-24, 16:44)mamachan Wrote: I' m not able to see Jack Ryan from Prime Video
In the Amazon app or Kodi addon?
Amazon app
Then contact Amazon.
32 or 64 bit Kodi for Fire Stick 4k?
32 bit
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Are all audio sync issues fixed now?
I have been asked to look for a hardware solution to run Kodi along with streaming add-ons and had thought the Fire stick 4k might fit the bill, especially at the current discounted price of around £30.
However it seems like it's not without issues and as I'm recommending this solution I dont really want any come backs from the person I'm recommending it to.
Personally I've used Raspberry Pi in the past, and now a Shield.
I was going to recommend them the Pi, but by the time a case, decent remote, etc is added to the cost it can work out a fair bit more expensive than the Firestick. Also the added advantage of being able to run Android apks is nice to have over the Pi.
Audio Sync for stereo is broken in their firmware for stereo sound. I did not find a way to estimate this 150 ms delay without a vendor hack.
While running Kodi 18.4, the screen turns blank but I can hear the navigation click from one item to another. In my log file I encounter the following lines -
cpp:
2019-11-25 19:13:00.611 T:3139   ERROR: GUI Shader gles_shader_rgba_oes.frag - compile and link failed
2019-11-25 19:13:00.612 T:3139   ERROR: CYUVShaderGLSL::CYUVShaderGLSL - failed to open file gles_shader.vert
2019-11-25 19:13:00.612 T:3139   ERROR: CYUVShaderGLSL::CYUVShaderGLSL - failed to open file gles_shader_rgba_bob_oes.frag
2019-11-25 19:13:00.614 T:3139   ERROR: GL: Error compiling vertex shader
2019-11-25 19:13:00.614 T:3139   ERROR: Compile failed.
                                            ERROR: Unexpected end of source found
                                            ERROR: 1 compilation errors. No code generated.
2019-11-25 19:13:00.614 T:3139   ERROR: GL: Error compiling vertex shader:
2019-11-25 19:13:00.614 T:3139   DEBUG: GL: vertex shader source:
2019-11-25 19:13:00.614 T:3139   ERROR: GUI Shader gles_shader_rgba_bob_oes.frag - compile and link failed
2019-11-25 19:13:00.625 T:3139   ERROR: Invalid GUI Shader selected - 3
2019-11-25 19:13:00.625 T:3139   ERROR: Invalid GUI Shader selected - 4
2019-11-25 19:13:00.625 T:3139   ERROR: Previous line repeats 2 times.
Here is the full debug log on Pastebin: https://paste.kodi.tv/imevuvohoy.kodi
Restarting my FireTV has temporarily solved it, but the issue still comes back pretty much immediately. I have removed Kodi and also re-installed Kodi. Does anyone have any good advice on troubleshooting this on the Fire TV 4K stick?
Thanks,
Raist
As a PC user for many years, I've been pleased with the Fire Stick 4K. It does have audio issues, but none I couldn't work around by changing the global audio offset, changing the output to "fixed," 5.1, and setting the applydrc hack as described in this message and its predecessors:
https://forum.kodi.tv/showthread.php?tid...pid2870459
I use my Fire Stick as a Kodi-only device, and by keeping the stick from sleeping as described in the link below, I never have to deal with the Amazon UI or restart the Kodi app, which is nice:
http://www.aftvnews.com/how-to-set-custo...hout-root/
(2019-11-25, 22:09)fritsch Wrote: 32 bit
Many Thakns.
I have the shield, appletv4k, xioami tv, and the firestick 4k. For the price of the fires stick when on deal. It kicks the but of all the other devices. If you just want streaming and kodi the fire stick is awesome.
(2019-11-26, 17:44)rwijnhov Wrote: I have the shield, appletv4k, xioami tv, and the firestick 4k. For the price of the fires stick when on deal. It kicks the but of all the other devices. If you just want streaming and kodi the fire stick is awesome.
But isnt this plagued with the audio sync issue?
its the only thing putting me off this for a purchase for a family member who is after a device that will run Kodi and video streaming addons on their 720p (HD Ready) Panasonic plasma.  Confused
(2019-11-25, 22:57)fritsch Wrote: Audio Sync for stereo is broken in their firmware for stereo sound. I did not find a way to estimate this 150 ms delay without a vendor hack.
Is there some way to automate that delay so it only applies to stereo and not other files?  I only noticed it on stereo aac so far.
  • 44
  • 45
  • 46(current)
  • 47
  • 48
  • 119
2018 - Amazon Fire TV Stick 4K3
