fritsch
Team-Kodi Developer
Yeah - would be okay. I am the author of both. Btw. does my precompiled apk work for you? (It's Leia so won't kill anything)
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
fritsch
Team-Kodi Developer
What's special in your version? Any fixes we need? If you build yourself anyways, have a look in my fritschfiretv branch - here is everything integrated that's too large for Leia backport on Leia base.
fritsch
Team-Kodi Developer
I am waiting for your logfiles and for the "description" of "sense that audio sync is slightly off" <- this slightly I am interested in. Is this 100 ms - is it 50 ms?
Reason why I am asking: there is no other public API available to measure the delay.
fritsch
Team-Kodi Developer
I did some testing overnight, with all old videos I could find and stereo sound:
- Mama-Mia mpeg4 + mp3
- 23 - mpeg2 + mp2
- Sweeney Todt - mpeg4 + mp3
All were horribly out of sync before and are now working really fine. So I think it's working in general. Never the less I want to have such an AAC sample, it might be that it uses the mediacodec audio decoder for it.
fritsch
Team-Kodi Developer
Your logs look great, btw. the dealy is stable and everything works as it should. Wherever this delay is coming from, it's not from a user measurable AudioTrack delay source, cause:
VideoPlayer is happy as well! It would directly resync the stream if it thinks that delay is > 200 ms wrong. For the Dolby file, you basically get the exact same stats from the sink, which is exactly what I expected, cause Dolby is decoded to PCM, same for AAC - so it's just clear that the Sink behaves exactly the same, cause it only gets PCM data.
HDR10 HEVC 59.940 fps <- 59.94 fps ... not sure this is good the firetv. All those two files are perfectly in sync with e.g. nvidia shield / PC?
