2020-03-07, 11:47
(2020-03-07, 09:19)blizzardreign Wrote:(2020-03-05, 19:24)Kodroid Wrote:(2020-03-05, 09:05)blizzardreign Wrote: Ahh OK I understand. Is there any way I will be able to obtain those builds?http://mirrors.kodi.tv/test-builds/android/arm/
Thank you. Will the 64 bit version work for Firestick 4k?
Could someone shed light on whether I can get higher than 100mbps using the UGREEN USB 3.0 adapter with an OTG cable?
No - it's 64 bit chip, but 32 bit firmware. No advantages anyways -> Use 32 bit ARM.
