2020-03-08, 16:28
(2020-03-08, 16:15)jubilex Wrote:(2020-03-08, 15:00)fritsch Wrote:(2020-03-07, 22:24)jubilex Wrote: So that seems to be an issue between my Fire TV and my AVR that I'll have to find a solution for, or give up and go with Rpi4.
Any ideas about the issue of 2.40 aspect ratio trailers being stretched vertically to 16:9? I can't think of a reason for that since 2.40 aspect ratio full movies display correctly. And this, too, happens only with my Leia installation on Fire TV 4k and not my Leia installation on Rpi3/Librelec, running the same version of Cinemavision add-on and plugged into the same AVR and displays.
Please verify that in FireTV Screen Settings you have:
- Screen resolution automatic
- Color Mode automatic
- Switch to original refreshrate enabled
(translated from german, might actually be named differently)
Start kodi, turn on debug logging, turn off kodi, start it again and post a Debug Log, please.
Thank you for your help. I had not been aware of your Fire specifc version, I have downloaded the latest one now and will report back later after installing. The above settings match what I have.
The only changes in my build are audio changes, cause they could not be merged into Leia. All the rest is exactly the same.
