  • 5(current)
  • 6
  • 7
  • 15
Solved SONY AF9 w/ AndroidTV Oreo - Installation via Play Store fails with Error Code -506
#61
Does anyone have a Kodi 17.6 with package Id changed for Android TV? I have tried Kodi 18 but some of my add-ons don't work
(2019-01-01, 22:46)SamH Wrote: Thanks. All working now!!
Do you know if it's possible to view 4k content on the KD55AF9? It seems from discussions on here that it isn't possible?
 I play every 4k videos without any issues.
I play everything in 4K with out problems...
The audio gets advanced little by little when plays DTS-HD...any idea? At starts sounds good...
Which is the latest version we can use? I have tried to install v18 rc4 both in 32 and 64 bits, and it is not possible...
Can the developers make Kodi run on WebOS of LG TV? It's so perfect.
(2019-01-04, 15:56)hoang.hien2903 Wrote: Can the developers make Kodi run on WebOS of LG TV? It's so perfect.
 @peak3d  want to comment?
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
My  z9f plays most 4K content fine.
Compare to shield TV, it does has some problems.
Both SPMC and Kodi 18 have micro shudder with Dynasties UHD REMUX, for example,  20 seconds from start of S01E01 or E02.
Not sure this can be fixed by setting, I tried turn off motion options, but same result.
Is there an add-on to use the internal satellite reciever of the AF9 with some cccams in kodi?
Hello there. I bought AF9 too. I downloaded the modified .apk file on page 4 box.com. (kodi-armv7a-20190107-93e9045.apk)
But I don't know how to install it using the X-plore program. Can you tell in detail?
Found a report to this issue on heise.de today. Link
HTPC: Windows 10 Pro 22H2, Zalman HD135, Intel i3-7100, GTX 1070, UHD ASUS BW-16D1HT
NAS: Xpenology 7.2 Update 1, Intel i5-6600
750d user, oreo installed, kodi works fine here, version 18. rc 4
i highly doubt they purposely blocked kodi, if you can sideload an kodi 17 version on an AF9 and it works ... where is the thought process that sony has blocked kodi?
Main System - HTPC - Intel I3 6300 - Asrock z170 - 16 GB DDR4 - 128gb SSD - 65" UHD HDR Sony Android TV - Pioneer VSX 1130-K - 7.2.2 speakers
Other devices currently in use - 55" 3D UHD LG TV - 2 Fire TV's - Nexus Player - MiniMX s905 - Voyo Vmac Mini
Ubuntu Server - 12 TB NAS - MYSQL - Torrent Box
(2019-01-07, 20:08)dukester Wrote: 750d user, oreo installed, kodi works fine here, version 18. rc 4
it's a problem on new Sony TVs. Yours is from 2016.
https://torrentfreak.com/first-sony-prom...vs-190107/
https://www.heise.de/newsticker/meldung/...67183.html
Board already mailed them, to get the technical facts right.
Hi - in order to clarify the real issue, we just build two new version with simple changes:
a) sonyamazon see: https://github.com/fritsch/xbmc/commit/6...68c6b6d083
b) sonyrandom see https://github.com/fritsch/xbmc/commit/6...e745d56268
It would be nice if someone with the affected TVs could please test both these build, which are uploaded in some minutes here: http://mirrors.kodi.tv/test-builds/android/ for ARM and ARM64
I hope they build through - as we don't fake PACKAGE_IDs every day.
Thanks much for your help on this.
Official Update: After publication of this article a Sony PR representative told TorrentFreak that the company does not curate recommended apps. The representative added that Kodi is just one of several thousands of apps on the Google Play store and Sony has no ability to block these apps and does not do so. We’re seeking further clarification.
  • 5(current)
  • 6
  • 7
  • 15
SONY AF9 w/ AndroidTV Oreo - Installation via Play Store fails with Error Code -5063
