Network is slow, just downloaded.
And kodi-20190104-99374761-nghttp2-armeabi-v7a.apk failed too.
$ adb install kodi-20190104-99374761-nghttp2-armeabi-v7a.apk
adb: failed to install kodi-20190104-99374761-nghttp2-armeabi-v7a.apk: Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE: Failed rename]
fritsch
Team-Kodi Developer
Perfect. Same PACKAGE_ID
For all: go with the org.xbmc.sony version :-) - I will post updates after every two / three days. So that you users don't suffer from the Rootkit company.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Great! Thank you fritsch.
And I installed tv-release.apk on my shield tv, it's all OK.
Seems no launcher icon, but can be opened from setting - apps -koditest - open.
2019-01-08, 19:43
(This post was last modified: 2019-01-08, 19:48 by goatl0rd.)
One question testing the last .apk...
In the Video section inside System Info, it says:
GPU: Mali-G71
Screen Resolution: 1920x1080 at 60Hz - Full screen.
It means that when I play a 4K video, 1080p is the maximum resolution? How can I check the resolution played?
thanks and sorry for the off topic...
fritsch
Team-Kodi Developer
Resolution mediacodec opened was 4k. Check with the "info key" of your TV's remote. The UI is rendered in 1080p, that's normal and better for the MALI.
fritsch
Team-Kodi Developer
Good. Then we leave it to Sony - to figure that out. Why Kodi cannot be installed on a factory-resetted device while "kodi if called differently" installs perfectly fine :-)
