Is there anyway of getting the hauppauge colossus 2 pvr to work with kodi without using nextpvr?
So no one has ever tried this?
2018-10-10, 21:57
(This post was last modified: 2018-10-10, 21:58 by Karellen.)
Don't know. The question is ambiguous. What are you trying to achieve? Are you looking for a nextpvr replacement or are you hoping for something else?
Your question is better of in the Live TV section of the forum. I will move it there.
Ok thanks for the info and sorry for little detail. I would like to hauppauge card without nextpvr directly within Kodi.
Atreyu
Posting Freak
2018-10-11, 20:29
(This post was last modified: 2018-10-11, 20:31 by Atreyu.)
You can achieve this without npvr, but not without some kind of backend.
So you still need a backend since Kodi does not directly handle that part
What kind of backend do I need or should I keep using nextpvr?
Atreyu
Posting Freak
If you use npvr and you are not having any issues, why change.
