stacka
Junior Member
It's no longer present upon installation of Leia beta 4.
Is there somewhere else I can get it from?
I have the same problem there is no more simple client between PVR clinets, what should i do?
I have that problem on xbox one
jjd-uk
Team-Kodi Member
Seems it was accidentally broken, a fix is on the way.
You will have to wait till next update which will be somewhere .........
2018-10-24, 19:43
(This post was last modified: 2018-10-24, 19:44 by budz.)
So share us IPTV Simple Client as a zip addon for Xbox One/UWP and everyone will be happy.
Happened when I upgraded version check earlier
Is there going to be a fix before the next Kodi update? Hope so as I use it alot
Anyway of going back to beta3 on Xbox one. It automatically updated and as others have said has now disappeared.
