Increased graphics load on new TV? Advice needed!
Hi guys
Been running KODI (Windows 10 64) for ages on my old 1080p TV with no issues. I've now bought a new tv (LG 55C7V) that is 4K. Although I am still outputting 1080p from my HTPC, I am getting a huge increase in graphics load when outputting to the new TV. Same content, same resolution, same PC and graphics card. As far as I can tell the TV must be causing this then? But the issue doesn't appear when playing back through VLC. Is the TV communicating with KODI? somehow asking it for more information or to sync or something? I'm getting dropped frames because the load is so high. Hoping to change some setting to reduce it.
Any ideas welcome!
KODI
Output Resolution: 1080p
TV Resolution: 4K
3D Graphics load: 79%
Screenshot: https://photos.app.goo.gl/qNRCmJQc88Wyxp3N9
TV Resolution: 1080p
3D Graphics load: 27%
Screenshot: https://photos.app.goo.gl/C9tHWACgA8o1BJq49
VLC
TV Resolution: 4K
3D Graphics load: 15%
Screenshot: https://photos.app.goo.gl/risx49Z5x4DRcoxr9
Screenshot: https://photos.app.goo.gl/eABemBSPbqwXa1QV8
Can anyone helpHuh
Maybe you are switching to a 4K resolution at playback start with Kodi? Check the resolution whitelist if you are using v18.
Post a debug log (wiki) of your issue.  That will probably reveal what is going on.
Learning Linux the hard way !!
It's most likely the load rendering 60 fps with 4K and a lots of repaints.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Increased graphics load on new TV? Advice needed!0
