Solved Cannot get PlayerControl(tempoup) to work with 18.0b5 ... no effect on playback speed
I read this thread wherein the PlayerControl(tempoup) and PlayerControl(tempodown) commands are shown which allow speed up of video+audio up to 1.5x.  I added the code shown at that link to a new textfile ~.kodi/userdata/keymaps/custom.xml
When I launch kodi with debugging, recognizes that I am hitting that button to use the command, but there is no effect on video playback. I am running 18.0b5 on Linux x86_64. Thanks for any insights.
Complete debug log: https://gist.github.com/graysky2/c5b8ef0...e6ccb25563
Snippet:
13:28:10.288 T:140522416964416 DEBUG: Keyboard: scancode: 0x23, sym: 0x005d, unicode: 0x005d, modifier: 0x0
13:28:10.288 T:140522416964416 DEBUG: HandleKey: closesquarebracket (0xf05d) pressed, action is PlayerControl(tempoup)
13:28:10.405 T:140522416964416 DEBUG: Keyboard: scancode: 0x23, sym: 0x005d, unicode: 0x0000, modifier: 0x0
13:28:11.388 T:140522416964416 DEBUG: Keyboard: scancode: 0x23, sym: 0x005d, unicode: 0x005d, modifier: 0x0
13:28:11.388 T:140522416964416 DEBUG: HandleKey: closesquarebracket (0xf05d) pressed, action is PlayerControl(tempoup)
13:28:11.471 T:140522416964416 DEBUG: Keyboard: scancode: 0x23, sym: 0x005d, unicode: 0x0000, modifier: 0x0
13:28:11.871 T:140522416964416 DEBUG: Keyboard: scancode: 0x23, sym: 0x005d, unicode: 0x005d, modifier: 0x0
13:28:11.871 T:140522416964416 DEBUG: HandleKey: closesquarebracket (0xf05d) pressed, action is PlayerControl(tempoup)
13:28:11.955 T:140522416964416 DEBUG: Keyboard: scancode: 0x23, sym: 0x005d, unicode: 0x0000, modifier: 0x0
13:28:12.905 T:140522416964416 DEBUG: Keyboard: scancode: 0x22, sym: 0x005b, unicode: 0x005b, modifier: 0x0
13:28:12.905 T:140522416964416 DEBUG: HandleKey: opensquarebracket (0xf05b) pressed, action is PlayerControl(tempodown)
13:28:12.988 T:140522416964416 DEBUG: Keyboard: scancode: 0x22, sym: 0x005b, unicode: 0x0000, modifier: 0x0
13:28:13.405 T:140522416964416 DEBUG: Keyboard: scancode: 0x22, sym: 0x005b, unicode: 0x005b, modifier: 0x0
13:28:13.405 T:140522416964416 DEBUG: HandleKey: opensquarebracket (0xf05b) pressed, action is PlayerControl(tempodown)
13:28:13.488 T:140522416964416 DEBUG: Keyboard: scancode: 0x22, sym: 0x005b, unicode: 0x0000, modifier: 0x0
13:28:16.838 T:140522416964416 DEBUG: Keyboard: scancode: 0x40, sym: 0x0134, unicode: 0x0000, modifier: 0x100
Need help programming a Streamzap remote?
Have you enabled sync playback to display?
(2018-11-11, 21:12)Rechi Wrote: Have you enabled sync playback to display?
 No... that was my problem.  Thank you for the pointer!
Just to complete it. The documents are sometimes helpful in those cases Wink
https://codedocs.xyz/xbmc/xbmc/page__lis...nctions_12
There's a note under the possible player controls mentioning exactly that
Cannot get PlayerControl(tempoup) to work with 18.0b5 ... no effect on playback speed0
