Linux ./tinyMediaManagerCMD.sh -rename
Hello,
I find tmm really good. But I have a problem with the command:
I'm back:
dje@asrock:~/Téléchargements/tmm_3.0-SNAPSHOT_d45f8c7_linux$ ./tinyMediaManagerCMD.sh -rename
2018-11-18 00:39:00,276 INFO  [main] org.tinymediamanager.TinyMediaManager:158 - =====================================================
2018-11-18 00:39:00,276 INFO  [main] org.tinymediamanager.TinyMediaManager:159 - === tinyMediaManager © 2012-2018 Manuel Laggner ===
2018-11-18 00:39:00,276 INFO  [main] org.tinymediamanager.TinyMediaManager:160 - =====================================================
2018-11-18 00:39:00,278 INFO  [main] org.tinymediamanager.TinyMediaManager:161 - tmm.version      : 3.0-SNAPSHOT
2018-11-18 00:39:00,278 INFO  [main] org.tinymediamanager.TinyMediaManager:162 - os.name          : Linux
2018-11-18 00:39:00,278 INFO  [main] org.tinymediamanager.TinyMediaManager:163 - os.version       : 4.15.0-39-generic
2018-11-18 00:39:00,278 INFO  [main] org.tinymediamanager.TinyMediaManager:164 - os.arch          : amd64
2018-11-18 00:39:00,278 INFO  [main] org.tinymediamanager.TinyMediaManager:165 - java.version     : 1.8.0_191
2018-11-18 00:39:00,724 INFO  [main] org.tinymediamanager.TinyMediaManager:605 - default encoding : UTF-8 | UTF8 | UTF-8
2018-11-18 00:39:00,724 INFO  [main] org.tinymediamanager.TinyMediaManager:605 - set encoding to  : UTF-8 | UTF8 | UTF-8
2018-11-18 00:39:00,724 INFO  [main] org.tinymediamanager.TinyMediaManager:194 - System language  : fr_FR
2018-11-18 00:39:00,724 INFO  [main] org.tinymediamanager.TinyMediaManager:195 - GUI language     : fr_FR
2018-11-18 00:39:00,944 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.album.universal.conf' - using defaults
2018-11-18 00:39:00,953 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.artists.universal.conf' - using defaults
2018-11-18 00:39:00,959 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.themoviedb.org.conf' - using defaults
2018-11-18 00:39:00,964 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.tvdb.com.conf' - using defaults
2018-11-18 00:39:00,968 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.album.universal.conf' - using defaults
2018-11-18 00:39:00,974 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.artists.universal.conf' - using defaults
2018-11-18 00:39:00,978 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.themoviedb.org.conf' - using defaults
2018-11-18 00:39:00,981 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_metadata.tvdb.com.conf' - using defaults
2018-11-18 00:39:01,138 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_fanarttv.conf' - using defaults
2018-11-18 00:39:01,170 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_opensubtitles.conf' - using defaults
2018-11-18 00:39:01,293 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_omdbapi.conf' - using defaults
2018-11-18 00:39:01,330 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_moviemeter.conf' - using defaults
2018-11-18 00:39:01,333 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_imdb.conf' - using defaults
2018-11-18 00:39:01,338 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_tmdb.conf' - using defaults
2018-11-18 00:39:01,348 WARN  [main] o.t.scraper.config.MediaProviderConfig:84 - Cannot load settings 'data/scraper_universal_movie.conf' - using defaults
2018-11-18 00:39:01,366 INFO  [main] org.tinymediamanager.TinyMediaManager:196 - Scraper language : français
2018-11-18 00:39:01,397 INFO  [main] org.tinymediamanager.TinyMediaManager:197 - TV Scraper lang  : français
2018-11-18 00:39:01,406 INFO  [headless] org.tinymediamanager.TinyMediaManager:225 - =====================================================
2018-11-18 00:39:01,407 INFO  [headless] org.tinymediamanager.TinyMediaManager:253 - starting tinyMediaManager
2018-11-18 00:39:01,465 INFO  [headless] o.t.thirdparty.MediaInfoUtils:75 - Using MediaInfoLib - v17.12
2018-11-18 00:39:01,710 INFO  [headless] o.tinymediamanager.core.movie.MovieList:333 - found 3 movies in database
2018-11-18 00:39:01,713 INFO  [headless] o.tinymediamanager.core.movie.MovieList:354 - found 1 movieSets in database
2018-11-18 00:39:01,760 INFO  [headless] o.t.core.tvshow.TvShowList:324 - found 6 TV shows in database
2018-11-18 00:39:01,768 INFO  [headless] o.t.core.tvshow.TvShowList:372 - found 7 episodes in database
2018-11-18 00:39:01,859 INFO  [headless] org.tinymediamanager.TinyMediaManagerCMD:345 - Commandline - rename & cleanup movies...
2018-11-18 00:39:01,862 INFO  [headless] org.tinymediamanager.TinyMediaManagerCMD:506 - Commandline - rename & cleanup new shows...
2018-11-18 00:39:01,862 INFO  [headless] org.tinymediamanager.TinyMediaManagerCMD:522 - Commandline - rename & cleanup new episodes...
2018-11-18 00:39:01,864 INFO  [headless] org.tinymediamanager.TinyMediaManager:376 - bye bye
I tested with the versions:
- 2.9.13
-2.9.14
-3.0
But the result is the same. While with GUI it works
 -update it's OK
 -scrapeAll it works as well
and the movies files are renamed at the same time. there are only TV series that are not renamed.
Any ideas?
Yes, this is currently intentional.
As the syntax page says, the "rename" is not (yet) working standalone, only in combination of former commands (like update, or scrape)
The reason behind might be, to not be able to mess around with your whole datasource...
Possible just a discussion, to rename independently...
tinyMediaManager - THE media manager of your choice :)
Wanna help translate TMM ?
./tinyMediaManagerCMD.sh -rename0
