2019-01-11, 21:10
I have 2 Kodi devices. Slave1 and Slave2 - both on the same raspberries and the same size of sd cards. Slave2 is the newest and was copied by dd-command.
Today I've checked my storage on the cards and was wondering why they are different.
I have the latest LibreElec on both devices.
Output complete capacity Slave1:
Output complete capacity Slave2:
As you can see: available storage takes 2.8G vs 1.7G - why
So I wanted to get deeper:
Output /storage capacity Slave1:
Output /storage capacity Slave2:
It is 100% the same - I'm not new to linux but how can this output makes sense...I'm already root, nothing is hided here....where are the approx. 2,4GB are hiding itself?!
I am eager to your responses....I don't get it until now....?!?!
MediaSlave1:~ # df -h
Filesystem Size Used Available Use% Mounted on
devtmpfs 338.5M 0 338.5M 0% /dev
/dev/mmcblk0p1 255.7M 141.2M 114.5M 55% /flash
/dev/mmcblk0p2 6.9G 5.2G 1.7G 75% /storage
/dev/loop0 131.1M 131.1M 0 100% /
tmpfs 344.0M 0 344.0M 0% /dev/shm
tmpfs 344.0M 6.0M 338.1M 2% /run
tmpfs 344.0M 0 344.0M 0% /sys/fs/cgroup
tmpfs 344.0M 20.0K 344.0M 0% /var
tmpfs 344.0M 0 344.0M 0% /tmp
MediaSlave2:~ # df -h
/dev/mmcblk0p2 6.9G 2.8G 4.1G 41% /storage
tmpfs 344.0M 6.5M 337.6M 2% /run
MediaSlave1:/ # cd /storage/
MediaSlave1:~ # du -hs *
13.4M Epg11.db
128.0K TV29.db
1.0K backup
1.0K downloads
4.2M fanart_own
88.0K grab_fanart.zip
38.0K lib
12.0K lost+found
1.0K music
1.0K pictures
1.0K recordings
1.0K screenshots
1.0K shutdown.py
9.5M skin_confluence_modified.zip
1.2M tvlogos
1.0K tvshows
357.0K videolanguage.zip
1.0K videos
MediaSlave2:/ # cd /storage/
MediaSlave2:~ # du -hs *
13.4M Epg11.db
128.0K TV29.db
1.0K backup
1.0K downloads
4.2M fanart_own
38.0K lib
12.0K lost+found
1.0K music
1.0K pictures
1.0K recordings
1.0K screenshots
1.0K shutdown.py
1.2M tvlogos
1.0K tvshows
1.0K videos
