Few days ago the icon for Downloads under Videos- Media Sources went black. All other icons are fine. I switched to a different skin and back, also tried to delete and reinstall the skin but can't find it under add-ons to install. Update said no updates to get
All icons are fine... Just the one has a dark blue box, white lettering for Downloads (shared folder on my PC) and where the icon is, is a solid black box.
Any ideas?
System 1: HK1 RBox - Android 11, S905X4 Quad-Core, 4GB DDR3 - CoreElec KODI 20.3
System 2: Beelink GT1 Ultimate - Android 7.1, S912 Octa-Core 1.5 GHz, 3GB DDR4 - CoreElec KODI 18
Storage: WD MyCloud EX2 Ultra NAS - 2x4TB WD Blue (WD40EZRZ)
Display: 55" TCL 55R615-CA 4K TV
Hitcher
Team-Kodi Member
There's a folder.jpg in it?
2019-01-12, 03:47
(This post was last modified: 2019-01-12, 03:52 by THRobinson.)
When I go to file manager and look, it doesn't show any
Nope, I lied... In Windows I could find one hidden but not through file manager on Kodi. Deleted the file and rebooted Kodi but still black. Some sorta cache file need cleaned?
Database\textures13.db? Will it rebuild itself?
Yes. Rename the textures13.db, and might as well rename the Thumbnails cache. It will all rebuild itself. Once it all looks ok, you can delete the renamed items.
Had the same happen again...new Android box, no banned add-ons.
Before I go deleting stuff, is there an approved add-on like Indigo that clears temp files, cache, etc...searched but not seeing any which given how many add-ons there are seems weird.
Hitcher
Team-Kodi Member
It's not simply a case of us approving an addon it's down the author to submit it for approval.
