WIP ODROID N2 - AMLogic S922X board from Hardkernel
#61
(2019-05-28, 19:22)Sholander Wrote:
(2019-05-28, 17:45)runningnaked Wrote: Has anyone tried Hi10p (h264 10bit) anime with the N2?
H264 Hi10P is not hardware supported on N2, it will use software decoding; so I guess 720p is max you can expect...
@runningnaked your sample, Hi10p with 16 ReFrames, plays without problems on my N2 with latest nightly, so my guess was wrong Smile
Amlogic Odroid N2_S922_4G, Amlogic Box X92_S912_3/32G_Android.7.1.2,  X96Mini_S905W_2/16G_Android.7.1.2 and Mecool KM8_S905X_2/16
(2019-05-29, 20:33)binhex01 Wrote: Yep that worked, playback was flawless, no video or audio problems that I could see, very smooth panning.
(2019-05-30, 00:50)Sholander Wrote: @runningnaked your sample, Hi10p with 16 ReFrames, plays without problems on my N2 with latest nightly, so my guess was wrong Smile
@binhex01 and @Sholander thank you both very much for testing it out and confirming for me. That file is pretty representative of the recent anime files I've been watching, so it looks like an N2 is in my future! Smile
@Sam.Nazarko I'm still keeping my Vero4k+ though. Love this thing!
Hey, I just got an Odroid N2 and was wondering: should I enable hardware acceleration?
What would be the advantages and the disadvantages?
I know it is supposed to take some load off the CPU, but in case a video plays fine with it disabled, should I enable it anyways?
(2019-06-30, 20:28)DarkSphere00 Wrote: Hey, I just got an Odroid N2 and was wondering: should I enable hardware acceleration?
advantages: low cpu, disadvantages: none
enough said really :-)
(2019-05-26, 20:37)CraigHB Wrote: I almost bought a Chinese Android box when I first started looking into Kodi, cheap way to try it, but I quickly got away from that idea.  General purpose SBC seems the best way to go with Kodi on Linux.
What other decent SBC boxes are available apart from Odroid C2/N2 and (to a lesser extent) RPi?
Haven't been on the forum much so sorry for the late reply.
There's several AMLogic SBCs supported by CoreELEC.  Of course the Odroid-N2 was the first of the S922X boards, but they're currently working on support for the Khadas VIM3. There's also the older S905X boards like the Odroid-C2, Libre Computer Le Potato, and Khadas VIM2.
Unless you're really intent on saving a couple bucks you'll get the best support for AMlogic with one of those.  There's always limitations running CoreELEC on an AMLogic Android box like those cheap ones you see a dime a dozen.  For example they're having a lot of issues getting the Bee-link GT King working right and it's already been said there will be limitations with that one.
If you're looking to go outside AMLogic, for example an RPi4, then you would be using LibreELEC which supports the RPi's Broadcom platform.  CoreELEC only supports AMLogic. The AMLogic S922X is actually more powerful than the RPi4 since the chipset is designed for media applications.  Has better video acceleration and more powerful processing.
Beware - I'm pretty certain the ODroid C2 is an S905 not an S905X box - so has zero support for HDR.
(2019-07-08, 11:45)noggin Wrote: Beware - I'm pretty certain the ODroid C2 is an S905 not an S905X box - so has zero support for HDR.
I hear HDI and 10 bit mentioned a lot in the context of some players not handling 4K bluray rips.
I need to read up on whether its actually a big issue.
If you only want to watch regular Blu-ray HD movies - then HDR and 10-bit support are less of an issue.
If you want to watch 4K content - then a large proportion of this is sourced from UHD HDR Blurays which are HEVC/h.265 10-bit and used HDR10 - and thus HEVC/h.265 10-bit HDR10 compatibility is required for playback of these.  If you only have an SDR display, then you also need a platform capable of playing 10-bit HEVC/h.265 HDR10 content AND tone mapping it to SDR. (Without this your content will play, but the content will look totally washed out, desaturated and 'flat')
Another format that is around us h.264 10-but (h.265=4 Hi10) This format isn't used in consumer content, but is popular for fan-shared anime. It's not a format that is widely supported for hardware decode (*) - so most platforms have to software decode it, which means a more powerful CPU is required than for other codecs that can be software decoded. A couple of very modern multicore ARM SoCs now have enough CPU power to do this for 720p and 1080p h.264 Hi10 content. (Apple TV 4K, ODroid N2 both seem to)
Beware of confusing HEVC/h.265 10-bit hardware acceleration support (which is now widespread) with h.264 10-bit hardware acceleration support (which is not widespread)
(*) Some Rockchip SoCs DO support h.264 10-bit hardware decode - which caused a bit of a surprise in the Kodi community.
  • 1 Vote(s) - 5 Average
ODROID N2 - AMLogic S922X board from Hardkernel51
