2019-03-31, 20:14
That didn't used to be the case so there appears to be a regression.
(2019-03-31, 18:53)seniorstone Wrote: Hi Karellen Just one last footnote, from testing it appears that Audio Books do have to be scanned to the library in order for resume to work properly.Can you explain what the problem is? I just tested this on a fresh install and added the source only, no scanning into the library, and I was able to create Resume points.
(2019-04-05, 04:51)Karellen Wrote: I cannot see anything wrong in your log.Hi Karellen I appreciate the time you've put into this, in the above quote you say from Videoes>Files, I have been trying to play mine from Music>Files can you just clarify which is right please.
I have tested this on 4 different v18 builds of Kodi with an empty library. I am able to Resume the audiobook from Videos>Files.
I have no idea what the problem could be. Sorry.
(2019-11-29, 09:43)aksnöld Wrote: So would you mind explaining what container you are using and how you prepered it to get the covers showing up in kodi?I am using mka files also created as described on the above wiki page. I did not embed any cover artwork in the file. I just added it to the folder containing the mka file as shown in the image below. When you scan the audiobook into the library, Kodi will find the artwork and use it. In my screenshot the cover is named folder.jpg. You can also use cover.jpg, but Kodi prefers folder.jpg and when you export, it is exported as folder.jpg which means you will end up with two files if you use cover.jpg.
(2019-11-29, 09:53)Karellen Wrote: I am using mka files also created as described on the above wiki page. I did not embed any cover artwork in the file. I just added it to the folder containing the mka file as shown in the image below.
Quote:But your mka file needs to be tagged with basic information otherwise Kodi will not be able to import it into the library. MusicBrainz Picard does not work with mka files so you need to use MP3Tag or similar.While this is working for some files it does not for some others (which were correctly scraapped with mp3 and are listed in musicbrainz.org - so the question what are the required tags (actuall I used titel and artist) with MP3Tag.
(2020-02-28, 16:53)kbpickens Wrote: The bad is that when I scrape it, Kodi ignores the genre tag. Any ideas?Can you provide a screenshot of your tags as shown in your m4b-tool or from mp3tag if you have that installed.
(2020-02-28, 20:54)Karellen Wrote:(2020-02-28, 16:53)kbpickens Wrote: The bad is that when I scrape it, Kodi ignores the genre tag. Any ideas?Can you provide a screenshot of your tags as shown in your m4b-tool or from mp3tag if you have that installed.
Alternatively you can install this addon and add the genre from within Kodi... https://forum.kodi.tv/showthread.php?tid=349035
(2020-02-29, 21:34)kbpickens Wrote: The Metadata Editor addon didn't find any information for the fileThen you would add a new genre. Has nothing to do with a nfo file being available.
(2020-02-29, 21:34)kbpickens Wrote: I would wonder if the problem is that the tag is stored in mp4 format instead of ID3, but the title and artist fields are being scraped.Sorry, not sure. Maybe @DaveBlake will know.
