There is still so much I don't know about Kodi!
So skins can use a multi image control to show a "slide show" of images located in a given folder, these may be previously cached or picked up directly from the folder. Makes sense as a way to support extra art when only a single thumb and fanart was supported by the core processing or held in the database. If items have a path property then I can see how easy that would be to use.
I think having the individual location of
all artist or album related images held in the db is a good thing. It means that the art can be anywhere, called anything (although using simple folder layouts and standard file naming to provide an automated pickup of local art), navigated/selected in diverse ways and shared by all addons and skins. I don't see that having art table entries for 11,000 artist extrafanarts would be an issue @
scott967, how about you test it out?
But to go with loading all types of art we need to provide core support for a multi image control that can be based on art type rather than a path. For example given "shot" it cycles through the art for that item with types shot1, shot2......shotN, or maybe shot*, even cover artist1.shot1, artist2.shot1 for a collaboration album. Does that sound correct as a requirement? Rather than a infolabel have a better control.
Meanwhile there is how best to support skins that use the current multi image control.
(2019-04-12, 04:27)scott967 Wrote: I think it is probably common that skins provided for the possibility of looking in a folder location (parent folder of the folder containing a song) or a user-defined path that could be used to construct userpath/artist/extrafanart. Of course there was the problem of illegal path chars as well as multiple song or album artists which result in a failure to display the desired extrafanart.
With the addition of the artist info folder, that made a logical location for artist extrafanart folders without the user having to nominate his/her own dedicated path in the skin for them.
Now thanks to artwork beef and the extra art feature of Kodi 18 it is possible to load all art into the library, though the multiimage control no longer works and so we need a kludge of using a fadelabel control to iterate through library fanarts (among other things it hard-codes the max possible fanarts). But in my case I have over 11,000 artist extrafanarts in my production music source artist info and I'm not sure about adding 11 000 arts to the library. So I am still going to support the extrafanart folder path for now.
Marcel agrees with me that more of the SHS functionality needs moving into core where it can be done more effiiciently, but has never found the time to discuss which functions and I don't have the time to dig about in the addon code and work out what it is used for. So I have no wish to send you off to use SHS, much rather ensure core Kodi better supports the skinner's needs.
My stupid question of the day - can skins make JSON calls? Sorry but I just don't know how that works at all.
I also don't know how kludgy it is using fade label with a series of types e.g. "fanart", "fanart2", "fanart3" etc. but I accept it is not ideal.
Likewise if you take the artist name as the artist folder name you will be right most of the time. I decided not to do much name normalisation, I guess I will have to wait for user feedback to discover if this was a mistake. The only special thing it does is when name is not unique it adds part of the mbid to the end. For 18.2 there are info labels for mbids too, so you could possibly include that in your path building approach.
While I don't think the skins should be doing clever things with path for artist I can see that the user themselves might want to see where the artist nfo and local art are being picked up from (for example on the artist info dialog), and that would suggest an info label for that use but not for the player UI.
Since my team colleagues are reluctant to have improvements in point releases (only bug fixes) there is little I can do for v18, and I think for v19 a better multi-image control (plus JSON exposure of artist folder) is the way to go. But still happy to discuss the practicalities further.
