2019-04-19, 21:32
(This post was last modified: 2019-04-19, 21:32 by User 206796.)
Can't install on Kodi v18.1 & Ubuntu 19.04
Attempted via ubuntu official repository v4.12.12. Got the following:
"The following packages have unmet dependencies:
kodi-pvr-mythtv : Depends: kodi-api-pvr (= 5.2.1)
E: Unable to correct problems, you have held broken packages."
Tried via Kodi "Install from zip file" github release v5.10.7. Got a failed to install from zip file notification from Kodi.
Any remedies, ideas?
(2019-04-19, 23:13)disaacso Wrote: (2019-04-19, 21:32)jsnj Wrote: Can't install on Kodi v18.1 & Ubuntu 19.04
Did you add the team-xbmc repo?
there is a cosmic version in there.
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
should install version 5.10.6 which is stable.
I did add that initially as I always do when installing Kodi. But only v4.12.12 is available for Disco Dingo at the moment which isn't compatible vKodi v18.1. Not sure why zip install of the 5.10.x versions doesn't work either.
you can use the unstable ppa or wait a day till 18.2 is released. Then the add-on will also be in the stable ppa
did you enable the addon in kodi?
Addons -> My Addons -> PVR Clients
