v19 OSMC test builds for Kodi 19
#61
18.8-91, 29 Sep 2019: Based off OSMC commit (4fdd5857) and newclock5 (06ad3e8)
XBMC:
  • [pvr] Remove PVRTypes.h and left align & and * (PR:16677, 7 commits, 115 files changed)
  • Fix thumb loading on info dialogs (PR:16678, 1 commit, 1 file changed)
  • [skins] allow vendors to supply their own logo (PR:16631, 1 commit, 10 files changed)
  • add System.AddonIsEnabled() infobool and EnableAddon() builtin (PR:13762, 2 commits, 5 files changed)
  • [pvr][dialogs][Estuary][keymaps] Rework Guide window's navigation controls (PR:16638, 1 commit, 22 files changed)
pvr.waipu:
  • Improve README: add installation section (PR:35, 1 commit, 1 file changed)
18.8-92, 3 Oct 2019: Based off OSMC commit (2fc540dad2) and newclock5 (06ad3e8)
XBMC:
  • [VideoPlayer] Change avsync handling (PR:16658, 1 commit, 1 file changed)
  • [pvr] Update and persist channel group members from client on boot if (PR:16696, 1 commit, 14 files changed)
  • [guiinfo][pvr][Estuary] Rename Listitem.IsPremiere to Listitem.IsNew. (PR:16697, 1 commit, 5 files changed)
  • [PVR] Refactor PVR jobs. Get rid of PVRJobs.(h|cpp). (PR:16698, 1 commit, 12 files changed)
  • [modernize] use-override (PR:16685, 1 commit, 174 files changed)
  • [PVR] PVRManager: Factor out playback state functionality into its own class (PR:16699, 1 commit, 21 files changed)
  • AESinkAudioTrack: Remove Headphone check - let Audiotrack handle it byself (PR:16692, 1 commit, 1 file changed)
  • [PVR] Refactor: Move PVR classes from xbmc/addons to xbmc/pvr/addons. (PR:16700, 1 commit, 32 files changed)
  • [pvr] refactoring - review fixup after merge of 16677 (PR:16680, 1 commit, 16 files changed)
pvr.mythtv:
  • use color from settings (b2809d1)
  • bump versio 6.2.2 (815ec08)
  • bump version 6.2.3 (1c33216)
18.8-93, 4 Oct 2019: Based off OSMC commit (e25158cb5) and newclock5 (06ad3e8)
XBMC:
  • [PVR] Rework PVR component source directory structure. (PR:16702, 1 commit, 60 files changed)
  • fixed: Double redact (PR:16691, 1 commit, 1 file changed)
  • Revert "[VideoPlayer] Change avsync handling" (PR:16706, 1 commit, 1 file changed)
pvr.waipu:
  • Improvements: Casting and base64 decoding (PR:34, 2 commits, 3 files changed)
  • Improvement: Allow cookie handling for curl on redirects (PR:36, 2 commits, 3 files changed)
18.8-94, 6 Oct 2019: Based off OSMC commit (2206e1067) and newclock5 (06ad3e8)
XBMC:
  • [pvr] refactoring - remove extra whitespace (PR:16703, 1 commit, 48 files changed)
  • added: as.xml option to disable Curl HTTP2 (PR:16601, 1 commit, 3 files changed)
pvr.iptvsimple:
  • Reload interval (PR:281, 8 commits, 28 files changed)
pvr.vuplus:
  • Support group (bouquet) channel order from the backend (PR:248, 17 commits, 52 files changed)
18.8-95, 7 Oct 2019: Based off OSMC commit (321e38fbd) and newclock5 (60bef867e)
XBMC:
  • Reduce log spam produced by AnnouncementManager (PR:16651, 1 commit, 5 files changed)
  • [depends] bump libbluray to 1.1.2 (PR:16665, 1 commit, 6 files changed)
pvr.hts:
  • Code cleanup: Apply Kodi clang-format ruleset. (PR:429, 1 commit, 56 files changed)
18.8-96, 10 Oct 2019: Based off OSMC commit (97b846e) and newclock5 (60bef867e)
XBMC:
  • Show Studio icons (e.g. on folders, episodes or movies) (PR:16298, 2 commits, 1 file changed)
  • AdvancedSettings: Fix arttype return (PR:16736, 1 commit, 1 file changed)
pvr.mythtv:
  • update cached bookmark on set (7b2eb07)
  • bump version 6.2.4 (ab1d276)
inputstream.adaptive:
  • Creation Spanish language (#318) (d28c658)
  • Implement multiple periods support (a5b1fab)
  • [dlfcn_win32] add patch for multichar path (1f19197)
  • [DASH] Fix startPTS for SegmentURL VOD streams (4af0910)
  • [Android] check if valid JNI::bytearray was returned in getPropertyByteArray (6d9be92)
  • Free sampledecrypter instances on period change (a5f2b59)
  • Add period time to PTS / fix wrong segment 1 for mediaRange (d6091b8)
  • Cosmetic (35b1662)
  • [Dash] detect subtitle stream labeled with video/mp4 (99b6dff)
  • Support MP4 type TEXT (44a2584)
  • [WebVTT] binary representation (17c1ffc)
  • Merge branch 'master' into Matrix (d9e76b8)
  • version bump 2.5.1 (c648d0e)
18.8-97, 11 Oct 2019: Based off OSMC commit (35b655f6) and newclock5 (60bef867e)
XBMC:
  • [settings] add some missing functionality required for add-on settings (PR:16660, 9 commits, 12 files changed)
  • [skin.estuary/pvr] Improve display of genre in PVR info dialog. (PR:16731, 2 commits, 1 file changed)
  • [skin.estuary/pvr] Add deleted to PVR Recordings breadcrumbs and increase width of info panel to fit 12 hour clock (PR:16739, 2 commits, 2 files changed)
  • [PVR] EPG database: Fix persisting/restoring of optional(!) firstAired data (PR:16738, 1 commit, 1 file changed)
  • [clang-format] change format for constructor init and switch/case indent (PR:16701, 4 commits, 2 files changed)
pvr.mythtv:
pvr.vuplus:
  • Group specific channel numbering to matching backend bouquets (PR:251, 5 commits, 15 files changed)
18.8-98, 12 Oct 2019: Based off OSMC commit (ade8315) and newclock5 (60bef867e)
XBMC:
  • [PVR] EDL: Passing unsupported items to CPVREdl::GetCuts is not an error (PR:16748, 1 commit, 1 file changed)
pvr.iptvsimple:
  • Fix channel logos (PR:291, 3 commits, 11 files changed)
18.8-99, 13 Oct 2019: Based off OSMC commit (39c4a66b) and newclock5 (60bef867e)
pvr.vuplus:
  • Fix recording timer (PR:253, 4 commits, 10 files changed)
18.8-100, 29 Oct 2019: Based off OSMC commit (1bd5f1199) and newclock5 (60bef867e)
Note: Kodi has now merged the changes for Python3. If addon dev's have not updated their builds for Python 3 then expect breakages.
Known issues: MyOSMC not yet working with Python3. This is being worked on.
OSMC
  • Add libpython3.5 as a dep
XBMC
  • [profiles] Do always stop PVR services on logoff #16842
  • System.HasAddon() - return true for disabled addons #16707
  • remove g_mediaManager global #16261
  • VAAPI: fix use after free in CVAAPIContextDestroyContext #16763
  • [addons][vis][gui] improve visualization support #16718
  • [addons][game] fix crash where NULL was given to stdstring #16829
  • Docs: Add python3-dev as dependency since we bumped the python version #16794
  • [pvr] Fix editing channels via channel manager #16799
  • xbmc.python bump to 3.0.0 #16787
  • [Estuary] add scrollbar to settings dialogs #16782
18.8-101, 4 Nov 2019: Based off OSMC commit (1bd5f1199) and newclock5 (46cda7db)
OSMC
  • MyOSMC (v3.0.680) Updated for Python 3.
  • Game.Libretro point to Matrix branch
XBMC
  • VideoLayerBridgeDRMPRIME: set HDR metadata (PR:16103, 2 commits, 7 files changed)
  • Add ratings bubble also to "Shift" view (PR:16732, 1 commit, 1 file changed)
  • [Estuary] fix studio icon name (PR:16758, 1 commit, 1 file changed)
  • Several Joystick keymap changes related to the B button and back buttons. (PR:15268, 1 commit, 1 file changed)
  • Move from python 2 to python 3 (PR:16116, 17 commits, 78 files changed)
  • [Music]Reduce repeated parsing of path to get node details (PR:16724, 1 commit, 5 files changed)
  • Code clarity: Separate GetVolumePercent() and GetVolumeRatio() (PR:16759, 1 commit, 11 files changed)
  • [guiinfo]Fix Musicplayer.Property(Role.xxx) info labels (PR:16784, 1 commit, 1 file changed)
  • Revert "[skin.estuary/pvr] Add support for more meta data to PVR info (PR:16788, 1 commit, 1 file changed)
  • VideoTagInfoLoaderFFmpeg: Resolve stack before trying to process (PR:16797, 1 commit, 1 file changed)
  • Revert setting playcount to PLAYCOUNT_NOT_SET on video items read from cache (PR:16804, 1 commit, 1 file changed)
  • Uniforming shown media flags in Movie library view and Info view (PR:16778, 3 commits, 2 files changed)
  • [Estuary] add scrollbar to settings dialogs (PR:16782, 1 commit, 2 files changed)
  • xbmc.python bump to 3.0.0 (PR:16787, 1 commit, 2 files changed)
  • Build cache filename using just path without options string (PR:16805, 1 commit, 1 file changed)
  • DRMPRIME: Cleanup and improvements (PR:16800, 10 commits, 12 files changed)
  • [pvr] Fix editing channels via channel manager (PR:16799, 2 commits, 67 files changed)
  • Docs: Add python3-dev as dependency since we bumped the python version (PR:16794, 1 commit, 5 files changed)
  • [addons][game] change addon system to C++ style (PR:16453, 3 commits, 24 files changed)
  • [addons][game] fix crash where NULL was given to std:Confusedtring (PR:16829, 1 commit, 1 file changed)
  • [addons][vis][gui] improve visualization support (PR:16718, 4 commits, 6 files changed)
  • remove g_mediaManager global (PR:16261, 1 commit, 57 files changed)
  • System.HasAddon() - return true for disabled addons (PR:16707, 1 commit, 2 files changed)
  • [profiles] Do always stop PVR services on logoff. Restart PVR service (PR:16842, 1 commit, 1 file changed)
  • Game add-ons: Document the subsystem architecture (b020fe1)
  • Game add-ons: Architecture documentation (#16776) (eea94f3)
  • CCpuInfo split, rework, and cleanup (PR:16098, 3 commits, 42 files changed)
  • Ensure that skin is reloaded when a profile is loaded (PR:16840, 1 commit, 2 files changed)
pvr.dvblink:
  • [lang] updated language files from Transifex (9d854c8)
pvr.filmon:
  • [lang] updated language files from Transifex (b2c4b01)
pvr.hts:
  • [lang] updated language files from Transifex (0c6d334)
pvr.mediaportal.tvserver:
  • [lang] updated language files from Transifex (88db569)
pvr.nextpvr:
  • [lang] updated language files from Transifex (12e37da)
pvr.vdr.vnsi:
  • [lang] updated language files from Transifex (c211e3e)
pvr.wmc:
  • [lang] updated language files from Transifex (06b0123)
pvr.waipu:
  • [debian] fix dependencies after 316c1a6 (PR:39, 1 commit, 1 file changed)
  • bump version 1.2.2 (ea5bc46)
18.8-102, 10 Nov 2019: Based off OSMC commit (2df626477) and newclock5 (46cda7db)
pvr.iptvsimple:
  • Move from RapidXML to Pugixml which supports c++11 features + tvg-id fixes (PR:297, 6 commits, 25 files changed)
pvr.waipu:
  • Fix Debian: Set rapidjson dependency >=1.1.0 (PR:42, 1 commit, 3 files changed)
  • Implement O2 authentication (PR:43, 2 commits, 10 files changed)
pvr.vuplus:
  • Fix timer title matrix (PR:264, 4 commits, 23 files changed)
18.8-103, 11 Nov 2019: Based off OSMC commit (9bdd3a4af9) and newclock5 (46cda7db)
XBMC:
  • CPUInfoLinux: add /proc/cpuinfo parsing for arm/aarch64 (PR:16884, 1 commit, 1 file changed)
18.8-104, 13 Nov 2019: Based off OSMC commit (47af55a7ed) and newclock5 (46cda7db)
XBMC:
  • fixed: Extension matching in FileDirectoryFactory was broken (PR:16892, 1 commit, 1 file changed)
pvr.hts:
  • [lang] updated language files from Transifex (793d133)
pvr.nextpvr:
  • [lang] updated language files from Transifex (535a202)
pvr.stalker:
  • [lang] updated language files from Transifex (c69e54b)
18.8-105, 18 Nov 2019: Based off OSMC commit (afa9fe99) and newclock5 (46cda7db)
XBMC:
  • RendererMediaCodecSurface: Announce vertical shift as well (PR:16907, 1 commit, 1 file changed)
  • [cmake]Fix FindPython to find python.h correctly (PR:16905, 1 commit, 1 file changed)
  • kodi-send: python3 fix (PR:16896, 1 commit, 1 file changed)
  • [videoplayer] allow custom headers to be sent to ffmpeg & inputstream class property (PR:16847, 3 commits, 7 files changed)
  • WinSystem: Allow ALSA+PULSE in parallel (PR:16913, 1 commit, 4 files changed)
  • [Py3] cleanup pt.1 (1f4dfb7)
  • [Py3] cleanup pt.1 (#16786) (27be814)
  • [json] Add missing "status" string for VideoLibrary.GetTVShowDetails (PR:16885, 1 commit, 3 files changed)
  • 0 Vote(s) - 0 Average
OSMC test builds for Kodi 1900
