Tv headend is a community package for the symbology nas so yes it’s native. (No need for docker)
No point in paying silicon dust for epg and record as tvh does this automatically. (Surprisingly simple to set up if ota epg((uk)) a little more complicated if importing an xmltv file.
I’ve used this setup for over a year. Mainly to access tv from overseas hotels and it works
Perfectly with scheduling and live tv.
You can add IPTV channels to the tvh also if needed.
2019-06-12, 23:02
(This post was last modified: 2019-06-12, 23:03 by DarrenHill.)
Yes, you can route the directory that the saves are made to onto any mounted or connected drive (network or USB). Initially I had mine routing to a USB HD, but then switched it out to my NAS box as I started to run out of space.
GeoffG
Junior Member
2019-06-14, 04:24
(This post was last modified: 2019-06-14, 04:25 by GeoffG.)
Perhaps I've missed it somewhere along, but I see no mention of scheduling. In fact, this is the most important aspect of the HDHomeRun subscription. I previously used NextPVR and subscribed to Schedules Direct for EPG data. That alone is $25 dollars, so SD asking $35 for EPG and server based updates is more than fair. I'm confident enough with the setup, I recently upgraded to the Quatro (4 turner) system.
The MyPassport can do it fine, albeit with a little limited storage capacity once you get going if you plan on keeping stuff.
OSMC has an addon for TVHeadEnd server I think, so just install that and configure it via its web interface (normally on port 9981). Set the TVH server to get its input from the HDHR and then use the TVH PVR addon within Kodi and you're away.
There are numerous tutorials but a search away on the internet for how to set up a TVH server.
