2019-06-04, 09:29
2019-06-05, 07:54
prior to last fall we had problems to cache some sort of artwork (especially ones with transparency). This has already been fixed a few months ago.
Additionally we need different artwork sizes in v3 thus the cache is also different (smaller) - so you could drop the cache and rebuild it. it should become smaller
2019-06-05, 08:48
So can I manually completely remove the entire folder \Tiny MediaManager\cache with the 740.000 images in?
And may be not download those images? Do I have to remove those already existing foldes manually as well? Or can tMM to it?
extrafanart
extrathumbs
.actors
Or are the above not available at all in the image cache?
extrafanart
extrathumbs
.actors
2019-06-08, 19:18
A similar question, when I just want to start from the beginning, re-scrape all the movies, should I manually remove the entire folder "cache" or should I let TMM do it? If yes, what is the best way?
