Anyone having an issue with changing channels in Kodi v18? Using NPVR, changing channels is less than a second.
Is there some setting I need to disable? Sometime it takes so long that the channel is time shifted a few seconds.
Although you still won't get NextPVR client speed optimization, if your goal is fast changing configure real time mode.
Martin
If you post both your Kodi debug logs and the compressed NextPVR logs here or on the NextPVR support forum we can have a look. It would be good to include a test showing tuning in Kodi and in NextPVR itself.
Martin
Although that is not the debug Kodi log, it looks there is a difference in the tuning process when changing channels on the windows client. The first tune is the same time as Kodi but there looks like optimization on the graph changes that the web server doesn't use. sub would need to explain any backend difference to see if improvement is possible.
Martin
You've missed a couple:
2019-07-08 10:55:21.526 T:14288 NOTICE: ADDON: plugin.program.indigo v2.0.2 installed
2019-07-08 10:55:21.527 T:14288 NOTICE: ADDON: script.tvaddons.debug.log v1.0.7 installed
The former you can maybe get rid of by uninstall, but the latter will probably need to be removed manually (it's one of those orphaned scripts that stays behind even when you uninstall the main add-on, another reason why we "love" these things so much...).
To do that, close down Kodi, and open the folder C:\Users\flyin\AppData\Roaming\Kodi\addons in file manager (or your file app of choice). In there you should find sub-folders for each addon installed on your system. Just delete the one for script.tvaddons.debug.log and if you haven't removed it elsewhere also for plugin.program.indigo . You should then be good to go on the next boot of Kodi.
Yup, all clean now, although depending on the issue it may also need debug logging enabled (Settings > System Settings > Logging) and perhaps some of the component logging as well (same screen).
But let's see if things as they are is enough for someone more knowing in this area to help (not me I'm afraid).
"sub3" Are you able to shed some light on this? Thanks!
