Configuring direct access to Movies and TV Shows
I'm certain I am missing something obvious so please forgive me in advance.  Is there a way to set up this skin such that selecting Movies or TV Shows automatically goes in to the configure Movies or TV Show folder? I'm looking to avoid the extra step that shows all configured folders - i.e. Select Movies from the main menu, then select Movies again from the second menu which enumerates all source folders and related options.
Apparently I cannot edit my post. The question should say "Is there a way to set up this skin such that selecting Movies or TV Shows automatically goes in to the configured Movies or TV Show folder?"
(2019-07-04, 07:16)daphatty1 Wrote: I'm certain I am missing something obvious so please forgive me in advance.  Is there a way to set up this skin such that selecting Movies or TV Shows automatically goes in to the configure Movies or TV Show folder? I'm looking to avoid the extra step that shows all configured folders - i.e. Select Movies from the main menu, then select Movies again from the second menu which enumerates all source folders and related options.
@daphatty1,
Skin settings menu underMedia Entry Points sub menu.
Wyrm
If required a FULL debug log can now be submitted from the skin in settings->skin settings->support. Or follow instructions here if you can't access skin settings.
FAQ's located at :- http://kodi.wiki/view/Add-on:AppTV
Configuring direct access to Movies and TV Shows0
