Hitcher
Team-Kodi Member
2019-08-07, 16:26
(This post was last modified: 2019-08-07, 16:31 by Hitcher.)
Container(10051).ListItem.Duration is working perfectly but Container(10051).ListItem.Mpaa is empty. Am I missing something?
Fml, used the language locale instead of getting a country locale. I guess I have to rewrite the language setting logic to cover the full locale string like en-US.
Main: Lancool II Mesh - Ryzen 9 5900x - MSI x570 Unify - Zotac RTX 3080 AMP HOLO - 32GB Trident Z Neo 3600 CL16 - EVO 960 M.2 250GB / EVO 940 250GB / MX100 512GB / Crucial P1 2TB / WD Blue 3D Nand 2TB
Sound: Saxx AS30 DSP - Beyer Dynamic Custom One Pro
TV: Nvidia Shield 2019 Pro- Adalight 114x LEDs - Sony 65XG9505 - Kodi / Emby - Yamaha RX-V683 - Heco Victa 700/101/251a + Dynavoice Magic FX-4
Server: i3 Skylake - 8GB - OMV4 - 22TB Storage
Quick fix added on GitHub. Until I find a better solution -> You can set the certification country in the addon settings.
Do you know if we have a list somewhere with used prefixes for different countries?
In Germany for example we have "FSK 16" but TMDb only returns "16".
Finished the shipped windows and added the script to my personal repo.
These windows can be used for reference as long as I'm not finished the documentation.
It's now also possible to call the script directly.
The Embuary integration is also 99% done and I'll submit the script to the Kodi repo soon.
Hitcher
Team-Kodi Member
I've completely removed Extended Info and Toolbox scripts and replaced them with this and your Helper script. Both working very well.
One little bug I found though is when you view the actor images and open any other image but the first one in the image viewer and then scroll through them instead of the next image in the sequence it starts at the first one.
I dropped custom skin strings for mpaa a long time ago. They doesn't make sense if a item is returning a rating from another country as fallback or because of another reason. The value itself has to be the correct one.
Hitcher
Team-Kodi Member
Thanks once again.
And certifications are a right pain for skinners.
I've submitted it to the Kodi repo. Just waiting for the review and the merge.
