v18 No video
Hi there i have kodi 18.3 installed on raspberry pi 4b when i open a movie there is sound but no video i did check the settings under video "rendering method " but mine is greyed out can sumone help please
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Is your HDMI plugged in to the port next to the usb-c/charging port?
Raspberry Pi4 (2x), Raspberry Pi5
Kodi Omega Beta2, Aeon MQ9 Mod-1.0.9
(2019-09-05, 08:43)Henk31 Wrote: Is your HDMI plugged in to the port next to the usb-c/charging port?
no its not if i plug it in on the 1 next to the usb then i dont get any display
hi my log file was pasted to http://ix.io/1Umk and the crash file to http://ix.io/1Uml
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2019-09-05, 19:12)OTinley Wrote: The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
hi here is my new logs sorry about the other logs i was testing divrent things to see whats happening http://ix.io/1Umt and the other log is http://ix.io/1Umu
thanks
thanks
No video0
