2019-09-18, 17:28
I'm currently running version 3.0.5-SNAPSHOT with a build date of 2019-09-18 00:24
When I go into Settings -> TV shows -> Renamer, under the Advanced options there is a setting for "Replace colons with" and you can either select blank or underscore (_). When I pick the underscore and close out settings and the app, then reopen the app, the setting has been changed back to blank.
