2020-04-05, 20:37
Anyone have a fresh .zip that works? raitsa at gmail.com would be happy to get it cos my versions are not installing.
(2020-04-05, 20:37)Raitsa Wrote: Anyone have a fresh .zip that works? raitsa at gmail.com would be happy to get it cos my versions are not installing.
(2020-04-08, 13:06)Rijs43 Wrote: Hi Marduk,
Just wondering how you progress in this very nice skin?
Q: in homescreen will there be any automatic play trailer option? (Same as Netflix)
(2020-04-08, 16:07)mardukL Wrote:(2020-04-08, 13:06)Rijs43 Wrote: Hi Marduk,
thx.
i have it in mind but no promise when/if it will get find a way in.
(2020-04-10, 00:05)Rijs43 Wrote: Hi Marduk,
I saw in the skin the line under poster for progress status and reminded me of Trakt and which looks great!
Please see attached picture of Trakt on how they show the % and was thinking if you would consider to implement same for ratings in your skin together with slightly rounded edges?
link
(2020-04-10, 13:19)mardukL Wrote:(2020-04-10, 00:05)Rijs43 Wrote: Hi Marduk,
link
I am not a fan of overays on 'item artwork' so i tend to reduce them to a 'needed/optional' minimum, same for infos (i didnt like to overload it)
the only overlay decision i will think about
are indicators like (e.g. part of movie set,episode counts)
(2020-04-15, 19:19)nazim12 Wrote: One request , OSD should be like when we Pause , Screen lights should not be dark or dim until after 5 to 10 sec even when we Skip forward or backward lights should not be Dim . Kindly consider it .
xml:(Player.Caching + !Window.IsVisible(busydialog))
(2020-04-20, 13:30)TomT Wrote: I really love it! Looking fantastic and different to other skins. Looking forward to beta stadium.
(2020-04-20, 14:19)mardukL Wrote:(2020-04-20, 13:30)TomT Wrote: I really love it! Looking fantastic and different to other skins. Looking forward to beta stadium.
Thanks ;-)
Got my hands on OSD now, but still so much left to to till beta will be ready :-(
OSD - 'plot info not avail, or 'toggled off''
Custom Color Tests
(2020-04-20, 17:36)Aaiemron Wrote: Great skin. Is it possible (or maybe will you make it possible) to make a favourite as a widget?
