Hello, very good job
There is a way to have the film covers in small landscape to have a line of 4 films because I see it in your videos but when I configure it I have a line of 3 films with large landscapes. Is there a possibility to have the less rounded landscapes, to make them like apple? THANKS
2021-03-05, 21:24
(This post was last modified: 2021-03-06, 10:25 by kow1234.)
if on fire stick 4k for fresh start click mouse toggle hover over menu till its highlighted click on it then click off toggle and press left on d pad and in menu pick settings skin settings and chose ur home lay out and put something in menu and set a widget and next start won't have to use toggle back button and d pad will move thing
Hello,
Great work, this has the potential in becoming THE skin for kodi UI. My little advice is to focus on getting the skin ready for use out of the box. I know users tend to twick the settings for their liking, but it would be nice if you could implement some sort of install wizard in witch you may include:
- trakt activation - independent trakt will allow you to create a kodi library folder based on user lists stored on trakt.tv
- make the user choose the default media streaming add-on, if installed
- make the user choose types of movies and TV shows and create a custom library folder based on ratings from TMDB or IMDB, trending or most popular, even a mix of those.
- choose default type view for home screen
Can't thank you enough for this work, I know it's time consuming, lots of trial and errors and maybe some users will brag for some features that are very hard to implement. Focus on your main vision on how the skin should be, gather what you think is best to implement as an idea and make it work.
Best of wishes and good luck.
P.S.: Don't forget about your family and take care of them
This all looks amazing.
The biggest issue I'm finding is with the Menu being keyed of M or with double Back.
Menu is tough to do with the Shield and 'back' is tough to get a handle on.
Other than that loving the potential. Nice work!
I like the circular navigation and u don't so should be option to choose left back to menu or back button I find easy to get to last item in widget with circular navigation
i don't like how the bottom of items in widgets in theme roundedge r square at the bottom posters square landscape and banner in unfixed mode all have square i avioded this in widgets cause i think the round edges look better
what is bg panel colors on 1st page says somethings about roudedge and bg panel color where is this setting
2021-03-09, 11:10
(This post was last modified: 2021-03-09, 11:14 by kow1234.)
i figured it out and i would say that this is the one totally crappy thing about this skin i dont like tags on my widgets but i do like rounded edges so im finding if i want rounded edges i have only 3 options without tags that r still rounded top and bottom and that is circle, poster & landscape, and banner fixed focus
im sorry but i dont see any option anywhere to set color to none can u plz tell me where this setting is r u talking about the tag setting
