2019-10-13, 17:32
Hi all,
I am having trouble playing this video file without doing a re-encode.
Thoughts?
Thoughts?
Quote:General
Complete name : D:\Downloads\complete\xxxxxxxxxxx\xxxxxxxxxx.Sat.Feed.1080i.H264.English.ts
Format : MPEG-TS
File size : 5.24 GiB
Duration : 24 min 55 s
Overall bit rate mode : Variable
Overall bit rate : 30.1 Mb/s
Video
Menu ID : 3 (0x3)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 4:2:[email protected]
Format settings : 4 Ref Frames
Format settings, CABAC : No
Format settings, Reference frames : 4 frames
Codec ID : 27
Bit rate : 27.8 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.537
Stream size : 4.85 GiB (92%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Menu ID : 3 (0x3)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Compression mode : Lossy
Stream size : 68.4 MiB (1%)
Language : English
Audio #2
Menu ID : 3 (0x3)
Format : MPEG Audio
Codec ID : 3
Bit rate : 384 kb/s
Language : English
