roze
Junior Member
I did EDL file for 'Cut' action - it works for me fine.
But I'm not able to create Scene Marker.
Also 'Showing EDL Information During Playback¨by pressing 'o' don't show me anything about EDL.
roze
Junior Member
I run Kodi on Win10, so I'm using classic PC keyboard - no remote control.
f:\Users\ro\AppData\Roaming\Kodi\userdata\keymaps\gen.xml is generated output from Kodi Keymap add-on for NextScene and PreviousScene action.
I'm not familiar with mapping keys, I guess there might be a problem here :-( .
I try to map these action on Numpad '4' and '6' key. It's my first key mapping - any suggestion to change?
First I would like to solve the problem with EDL, I have no problem with the sound right now.
roze
Junior Member
Bingo!! Scene Marker works now:-).
Thank you for your help.
2019-11-12, 20:32
(This post was last modified: 2019-11-12, 20:33 by Karellen.)
Great. I'll mark this thread marked solved.
If I, or anyone else, figures out the EDL display we will post here. The thread is still open.
roze
Junior Member
I would like to see clarified the description in wiki - the part showing EDL Information During Playback.
Currently, if I press 'O' nothing diplayed about EDL. It is nothing important, e. g. just write it is not possible.
Will do. But first I want to make sure that is not the case, and not some bug that has crept in and can be fixed.
roze
Junior Member
wow, Jesus, I don't believe my eyes...
I'm from Czech Republic, we have proverb... impossible immediately and wonders within three days
and you did it in less two days :-)
I'm looking forward for v19
thank you so much again
