Select unscraped movies OR After scraping, select the movies just scraped
When I go to 'rename & cleanup selected movies' after scraping, I either have to select all (cmd+a) my movies and click the button (takes a long time) or manually select the movies I've just scraped then click the button (much quicker but a manual process).
To automate things a bit more, I wonder if there could either be a feature prior to scraping: 'select all unscraped movies', so the items stay selected after scraping, or a feature whereby after you've clicked 'search & scrape unscraped movies', the items that have just been scraped get selected.. or maybe have both? I think this would help automate things a bit more
there is a filter with missing meta data.. this is probably the only thing you need..
tinyMediaManager - THE media manager of your choice - available for Windows, macOS and Linux
Help us translate tinyMediaManager at Weblate | Translations at 66%
Found a bug or want to submit a feature request? Contact us at GitLab
Select unscraped movies OR After scraping, select the movies just scraped0
