2020-01-11, 14:50
Is there anything in the future development that makes custom order easier for universe numbering in tinymediamanager .
for now i need to make for every Movie and tv shows a code or number so i could make custom order of any universe it is the only way to customized playlist if sorting needs to be done .
so if i must rename them ALL ( i got about 200+ tv shows with about 7 seasons per show not to mention movies) that would be a hell of a task.
oke i can use bulk renamer but when they go into tinymediamanager and rename those new videos that im scraping i need to do it manually again so that is not an solution for me.
now u would say why aren`t u not using sorting in kodi by number or by season , some seasons like for instance buffyverse or marvel doesn`t play synchronous with the numbering ,
example :
Buffyverse
airdate order BTVS season01 - season02 - season03 has no isseus
when Angel season01 starts 2 episodes after BTVS episodes are mixed into these it looks like this
Angel: 1x01 BTVS: 4x01 Angel: 1x02 BTVS: 4x02 Angel: 1x03 ......etc
this order is not correct cannon or chronological it needs to be ,
Angel: 1x01 , 1x02 BTVS: 4x01 , 4x02 , 4x03 Angel: 1x03
This is also with other Universes Airdate is at the moment the closest order but can change like for instance Marvel universe it keeps changing the order look for Captain marvel that was the last movie and it should be or could be in right order after Captain America first Avanger
My question is therefor why is there not a way to give videos a Code or number like (Buffyverse)
BUV0XXX to the name of the title/name of the video file so kodi would recognize also a alphabetic order
( https://kodi.wiki/view/HOW-TO:Movie_universe )
Once again i got a lot of videos and manualy giving them a number even in tinymediamanager is just a lot of work.
BTW i`m using smartplaylist and or Super Favorites to try this out and even now i need to put it manualy 1 by 1 to get a Correct order so i like it be be easier with some code that is already there ...
Thx in advance................
example :
Buffyverse
