Hi
I'm working with a developmental build on Android. V 19.
None of my addins are working and I'm confused why. Is there a new settings I need to have. Any advice is greatly appreciated.
Thank you.
Bobo
V19 needs python 3 compatible addons whereas v18.x used python 2. If your addons are not working, you should contact the authors of them and ask them to update them to python 3.
Learning Linux the hard way !!
Might there be a list of addons that are currently v 19 compatable?
Thank you,
Bobo
Hitcher
Team-Kodi Member
Just check what's available to install from the repo.
ronie
Team-Kodi Member
sadly there's no such list atm.
the repo in v19 also lists py2 addons that have not been updated.
Don't you think there should be a backward compatibility? Why we are facing such problem?
ronie
Team-Kodi Member
the main issue is there is no indicator in the addon.xml file that tells whether an addon is py2-only or py2/py3 compatible.
without such an indicator it is not possible to exclude the py2-only ones in the repo for v19.
jjd-uk
Team-Kodi Member
Damn I thought we agreed prior to Leia branch being open that all submissions would have to include Python 3 compatibility.
