Since around midnight (Dec. 4, 2020 0:00) every channel I select starts playing at the beginning position of the current show instead of the live feed. That's a neat feature that I could never get working in the past, but I really wanted to watch the news live!
I have two twin devices running Kodi Leia (LibreELEC 9.0.02) that developed the same behavior overnight.
Has anyone else encountered this? Perhaps an API change at Sling?
Thanks,
SBMag
2020-12-05, 02:07
(This post was last modified: 2020-12-05, 02:09 by taylormia.)
I have noticed the same experience. Every channel streams the ongoing show from the beginning/top of that hour. For example, if I start the channel at 5:30pm - the stream starts where the current show was at 5:00pm . In other words the channel is not a LIVE stream.
I'm using Inputstream Adaptive v. 2.4.5. This issue is present on my Windows 10 Kodi 18.9 as well as Libreelec Kodi 18.9
Any ideas for a fix?
2020-12-05, 05:53
(This post was last modified: 2020-12-05, 06:00 by MoreBloodWine.)
Mine barely started working again today in the same manner as y'all. As of right now it also seems a new wildvine update was pushed today. So fingers crossed as usual.
Edit: Seems it may be ok, not sure on feed position, but will reference against the roku later.
But using LE 9.2.6 on a RPI 3
Edit 2: Stopped and started it again and its position was the same commercial. Cant win for losing, or whatever the saying is.
But I concede and give up [emoji1787]
Just gonna stick w what's always worked...
2020-12-05, 19:14
(This post was last modified: 2020-12-05, 19:16 by MoreBloodWine.)
I don't recall if it was this add-on or another one.
But try lowercase sensitivity for the email, but obviously for the password that can remain case sensitive. But even if the email contains capital letters. I've had issues with at least two add-ons which again I think this might have been one of them, where the email only worked for the login ID if it was all lower case sensitive.
I know one would think that shouldn't cause an issue, but it has. But again, I don't remember if it was with this add-on but I think it might have been. Because it did with at least two thst I recall.
FUNimation is one add-on that I can say definitely that happened with.
2020-12-07, 10:23
(This post was last modified: 2020-12-07, 10:25 by MoreBloodWine.)
Dont know about anyone else, but I got bored, figured I'd mess w it a bit and let it play through. Call it curiosity killed the cat w insomnia and nothing good on to watch via other means.
Anyway... while based on the clock, it begins at the beginning of whatever "live" feed there is which is what everyone's pointed out so far, but then stops and goes back to homescreen vs continuing over once the feed for whatever time slot it was, is over. Don't think anyone's pointed that out yet.
Almost like what you might expect from on demand.
Aaaaaanyway... time to grab that late night snack and call it. Have fun yall !
This is a great app. I use libreelec on a rpi4. With the latest 9.2.6 version.
I am using this app with IPTV Merge to place the epg in iptv simple client. It appears Somewhere between the processing of the two apps in channel tag/category, simple tv is using a comma delimitator to separate multiple tags and iptv merge only recognizes semi colons. I am currently editing them away but is there anyway to use the same delimitator?
