2020-12-11, 17:22
(This post was last modified: 2020-12-11, 17:25 by MoreBloodWine.)
I cannot be certain without obviously watching it for a while. But it looks like the other issue might be fixed. I just turned on Cartoon Network on a whim, it pick right up in the middle of Craig of the creek, it seems.
Edit: Nm, just the way this particular episode starts.
The same happened to me after last update to widevine yesterday. I went into input stream helper and re installed the previous version on widevine. Now back functional.
I do not have live tv. Have the same VOD feel as before the most recent widevine upgrade. I just wanted to get everyone back up and running for today. I will wait for the experts to figure out the real problem when they get to it.
I am on a raspberry pi 4, The Slinger service is very problematic and makes the addon unusable for me. I would like to not use it at this point and I would like to keep it disabled. The temporary workaround toggle gets disabled when I disable the slinger slinger service. Can the temporary workaround toggle be separated from the slinger service? It would allow me to continue to use the addon. If that cannot be done, can you provide a disable for the on demand updates. Maybe via setting the update interval to 0 would disable update for that particular service. Thanks for all the work.
