Do I have to build nasm 2.14 on ubuntu or is there an alternate solution to be able to build dav1d?
Martin
lrusak
Team-Kodi Member
just install nasm via apt
"PPC is too slow, your CPU has no balls to handle HD content." ~ Davilla
"Maybe it's a toaster. Who knows, but it has nothing to do with us." ~ Ned Scott
If it's 18.04 then you can't get it via apt. 18.04 only has an older version. You have to download it from the focal ppa and install it with sudo dpkg -i nasm-blah.deb
Learning Linux the hard way !!
2020-03-16, 22:06
(This post was last modified: 2020-03-16, 22:06 by emveepee.)
I will try to be clearer. 18.04 doesn't include 2.14 as it was added in v19. Should I download the 19.04 deb file or do I need to custom compile it?
Martin
Ok that's the 20.4 one, I am not sure how to tell if different versions have different dependencies.
Martin
Yes thanks, once you said to try the deb I installed the correct package directly. No problem with the build after that.
Martin
spiff
Team-Kodi Member
2020-03-30, 11:23
(This post was last modified: 2020-03-30, 11:24 by spiff.)
the required build deps for 18.04 can be found in the kodi nightly ppa.
