  • 14
  • 15
  • 16(current)
  • 17
  • 18
  • 76
Release Disney+
(2020-05-19, 23:46)matthuisman Wrote: @jakepe88
See here: https://forum.kodi.tv/showthread.php?tid...pid2947397
It will also be in 18.7 which is close
Kodi 18.7 nightly biulds aswell as 18.6 crashes when i play the madalorian or starwars episode 9 on a firestick so i cant provide logs i got the latest adaptative update 2.4.5 ...just to let you know
Another user had that - it's a kodi issue pretty sure specific to firestick (doesnt do on shield)
Did you try playing back other content (other add-ons etc etc)?
Try disabling framerate switching / dolby vision etc and see if you can find what causes it.
18.7 is close - so if 18.7 nightly is broken - 18.7 may very likely be broken for Firestick as well
Could you quickly try this build:
https://jenkins.kodi.tv/job/Android-ARM/...bi-v7a.apk
Be great if you could post your findings over on this Github issue I have created: https://github.com/xbmc/xbmc/issues/17904
(2020-05-20, 06:00)matthuisman Wrote: Another user had that - it's a kodi issue pretty sure specific to firestick (doesnt do on shield)
yes the simpsons episodes are working fine i've tried alpha builds of kodi 19 and it does not do that
 however i'll try what you said and let you know
ok it works with the build you linked me only if i disable L1 secure device
also the DD+ tracks works again
(no audio on DD+ tracks if L1 Secure device is ON)
Sorry. 18.6 and 18.7 crash?
But 19 is fine?
Can you check the version of Inputstream Adaptive your using? Is it only happening with 2.4.5? Was 2.4.4 OK?
(2020-05-20, 21:57)matthuisman Wrote: Sorry. 18.6 and 18.7 crash?
But 19 is fine?
2.4.5
was the same with 2.4.4
(2020-05-18, 23:20)matthuisman Wrote: that will be because that includes the PR (https://github.com/peak3d/inputstream.adaptive/pull/451) that fixes the fps for HLS playlists.
The problem is still there I believe - but as Kodi is now switching to correct framerate before playback begins - the issue doesn't arise.
Also, that fix has just been backported to 18
So should land in 18.7
Can also download build of it here:
https://jenkins.kodi.tv/blue/organizatio.../artifacts
The above Leia build should be very nice and stable and work with everything nicely.
Is there also a version available for my Odroid C2 (aarch64) running CoreELEC?
I can only find an android version or armv7 for linux.
CorELEC is using 32bit userland.
Which is great as Widevine doesn't work with 64bit ARM.
So, just use the Linux ARMV7 version from here: https://forum.kodi.tv/showthread.php?pid...pid2947397
Translator
Nvidia Shield TV Pro 2019
LG Oled TV
Nightly Kodi 18.7/8
Kodinerds 19 Alpha
Disney+ Version 0.2.9
Films / Series
4K Dolby Version = OK
4K HDR 10 = OK
95% = OK
But somehow it still rattles in the box in the first seconds under Android until it runs smoothly ... although there are no automatic pauses after start ... even if L1 is switched off in the addon ... so it with 720p (no 4K plus Dolby Vision or plus HDR 10) is played ... also with the new Kodi 18.7/8 ... or the new Kodinerds 19 Alpha ... but this is not the case under Windows.
Tested with the series:  The Mandalorian
and with the film:  Togo
So it continues to rattle with the new Nightly Kodi 18.7/8 and Kodinerds 19 Alpha ... which is something like this
In the first approx. 12 seconds from the start of the stream ... So after the first few seconds the Dolby Vision Icon comes ... continues briefly ... then jumps back ... to about 4-5 seconds afterwards no picture
or sound ... then after the second Dolby Vision Icon and from 11-12 seconds everything is back to normal.
The same with HDR 10 ... or without HDR 10 and without Dolby Vision.
Also do not know how to describe it otherwise ... except rattle.
https://www.kodinerds.net/index.php/Thre...?pageNo=18
Can this commit help with these errors?
https://github.com/xbmc/xbmc/pull/17713
Could you please build a test build ... matthuisman ... that might help?
Sorry ...my english is not good...matthuisman.
if your talking about frame skipping - then that's a known issue in Kodi 18.7 and 19
See here: https://forum.kodi.tv/showthread.php?tid=354661
that should be fixed with this PR (only merged 21 hours ago):
https://github.com/xbmc/xbmc/pull/17943
If Kodi nerds build does not have that above commit - then there will be quite a few frame skipping issues on Android.
Can you ask the users to try Kodi 18.6 and see if has issue?
This problem is with this build
Nightly 18.6/7
Release 18.7
Nightly 18.7/8
available ... even after the FIX of @ peak3d
... but not with these Test build Kodinerds 19 Matrix Alpha from May 27th, 2020
... you can use it in parallel on the shield
... this is a test build from Uncle-W on Kodinerds.net
This Commint is now included in this test build.
Here is the new test build:
https://www.dropbox.com/sh/gzm82sztlkjyv...tracking=1
https://www.kodinerds.net/index.php/Thre...r-Android/
Oh yes, so it's the DMX issue (https://github.com/xbmc/xbmc/pull/17713).
Pretty sure that won't be merged in it's current form.
OK, here is Leia builds with that DMX commit in it and latest other fixes from peak.
ARM7 (FireTV 4k):
http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk
ARM8 (Nvidia Shield, Mi Box):
https://mirrors.kodi.tv/test-builds/andr...64-v8a.apk
Translator
LG Oled TV
Nightly Kodi 18.7/8
Films / Series
4K HDR 10 = OK
100% = OK
Tested with the series:  The Mandalorian and with the film:  Togo
Thank you very much ...matthuisman...this new Test-Build works fine on the Shield and has no Problems.  Smile
  • 14
  • 15
  • 16(current)
  • 17
  • 18
  • 76
Disney+13
