1st unwatched/in progress episode for each tvshow in a widgets panel?
I currently use service.skin.widgets to populate widget panels.  I was looking into replacing it just with skinning.  But one panel I can't see to duplicate is what s.s.w calls "recommended episodes" -- the first unwatched or in progress episode for each tv show.  Anyone do something like this in skin code?
scott s.
Not possible.
https://github.com/sualfred/script.embua...up-episode
This will return the next episode of a in progress TV show based on the last watched season. If the season has been completely watched, it will return the very first unwatched episode of the show.
Edit:
Plus you can filter by tag or playlist
Main: Lancool II Mesh  - Ryzen 9 5900x - MSI x570 Unify - Zotac RTX 3080 AMP HOLO - 32GB Trident Z Neo 3600 CL16 -  EVO 960 M.2 250GB / EVO 940 250GB / MX100 512GB /  Crucial P1 2TB / WD Blue 3D Nand 2TB
Sound: Saxx AS30 DSP - Beyer Dynamic Custom One Pro
TV: Nvidia Shield 2019 Pro- Adalight 114x LEDs - Sony 65XG9505 - Kodi / Emby - Yamaha RX-V683 - Heco Victa 700/101/251a + Dynavoice Magic FX-4
Server: i3 Skylake - 8GB - OMV4 - 22TB Storage
Thanks.  I figured that was going to be the case.
scott s.
1st unwatched/in progress episode for each tvshow in a widgets panel?0
