Stuttering/crashing video playback with network files
#16
I note a web call failure (script.tv.show.next.airedSmile and then this starts. (did you try with the default skin?)
2020-07-02 00:00:02.356 T:4128 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
2020-07-02 00:00:03.224 T:7068 WARNING: Previous line repeats 12 times.
2020-07-02 00:00:03.224 T:7068 WARNING: ActiveAE - large audio sync error: -10093.458388
and then goes on for many more audio sync errors.
Last shot... HOW-TO:Modify the video cache (wiki)
<advancedsettings>
  <cache>
    <buffermode>1</buffermode>
    <memorysize>139460608</memorysize>
    <readfactor>20</readfactor>
  </cache>
</advancedsettings>
Hi everybody,
Another try, this time as suggested on a portable, full stock install. Experienced stuttering but no crash (network file). Local playback runs fine.
Here is the log: https://paste.kodi.tv/nepikamuhi.kodi
I will try and post questions on the LimeWire/unRaid forum as well - if these issues are solved eventually, it might be helpful for other users Smile
Thanks again for your help and advice!
(2020-07-07, 10:38)Yarok Wrote: Experienced stuttering but no crash
Did you try modding the video cache as indicated in post #16 ?
ooh i'm afraid not, thanks for pointing that out - i missed your post because i kept this page tabbed and did not refresh before posting, sorry about that. I'll test the video cache mod ASAP!!
Hi again,
I modded the video cache as suggested on my regular install (not the portable one) - playback froze (without stutter) then stopped completely and jumped back to dashboard.
Here is my log: https://paste.kodi.tv/nemaxujemo.kodi
Next i will have to try portable/modded.
Thanks again!
(2020-07-09, 13:11)Yarok Wrote: Next i will have to try portable/modded.
Might be a good idea... and chose some lighter media such as a standard 8 bit h264 encode
"La.La.Land.2016.1080p.10bit.BluRay.8CH.x265.HEVC-PSA.mkv"  with CPU: Intel® Pentium® CPU G860 @ 3.00GHz, 2 cores available might be pushing it.
Of course you might be right, but before i've had so many troubles, i could play just about anything  Undecided
(2020-07-10, 00:00)Yarok Wrote: could play just about anything
Not 10bit.BluRay.8CH.x265.HEVC with Leia, you might look at the UHD threads or Matrix for that, but it's an old 2 core Pentium.
Hi @PatK , i could get an Intel i5-3470 3.20 GHz Quad Core 6Mb SmartCache for cheap, do you think it would help with my issue?
(2020-07-15, 14:19)Yarok Wrote: i could get an Intel i5-3470 3.20 GHz Quad Core 6Mb SmartCache for cheap
Why gamble, I don't know what cheap is, but when on a frugal budget and Kodi is the big attraction; The Nvidia Shield seems to have all the characteristics of a nice toy box.
30-ish euro ^^ but i'd rather try and fix/improve on what i have instead of buying new stuff.
In any case, i have another machine that could benefit from the i5 i mentioned so i bought it anyway, installed it and gave it a try yesterday - coincidence or not, i managed to have a smooth and uneventful playback of a feature-length movie. Still need to test it further though.
(2020-07-16, 23:05)Yarok Wrote: managed to have a smooth and uneventful playback of a feature-length movie
Might end up with the solve being the hardware?
Stuttering/crashing video playback with network files0
