2020-07-04, 01:53
(This post was last modified: 2020-07-04, 08:10 by Klojum.
Edit Reason: Typo fix in title
Dear all, I want to buy a TV box with the following Specifications:
1- It can passtrough to my soundbar Lossless Truehd and Master audio
2- playsback H 265
3- supports 4k HDR
4- it has sattelite antenna for sattelite channels
Is there any website with filter search?
noggin
Posting Freak
Yes - I'd definitely recommend going down the SAT>IP route these days. (USB DVB-S2 tuner support can still sometimes be a bit hit or miss, particularly when manufacturers change chipsets in models without updating their model number...). If you have a Quad/Quattro LNB then the Telestar Digibit 4 Tuner box is a great option - and you can also run third party firmware on it to add extra functionality (including Unicable II support - which I'm not sure the basic firmware has. Unicable II allows you to run a single LNB cable to the box and still have full 4 tuner support across all H/V/Hi/Lo bands)
